Boost leak? Turbo dead?
Old Sep 27, 2009 | 03:13 PM
12valvedutchy's Avatar
Hey guys im having boost issues or atleast that appears to be the problem.About a week ago i noticed my boost was down alot and my egts were high . I figured a boost leak. My hose from the turbo to intercooler looks like its in rough shape but i cant see or feel and leaks. I checked my airfilter and intake and everythings clean and tight. Should i replace the hose and look for improvment? or should i check my turbo too? i was seeing 20psi of boost lastweek when it started and now im seeing 10 -13psi. It takes forever to get the turbo to spool which worries me. Any help would be appreciated. I cant drive it anymore the way it is. EGts get to 1200 and 1300 too quick. TIA
Jordan
Old Sep 27, 2009 | 04:01 PM
1985cucv's Avatar
yeah maybe a boost leak somewhere i would change the boot out and go from there.
Old Sep 27, 2009 | 04:57 PM
megacabdad's Avatar
Did you spray all the boots with soapy water or leak detector soap?
Check the turbo for excessive end play?
Old Sep 27, 2009 | 09:08 PM
Thanks. I sprayed the hose that looked worn but didnt see much. I havent had much free time to check everything so ill look again for a goodlook. Ill check for play also. Shouldnt be much but ya never know
Jordan
600 Megawatts
Mar 26, 2008 07:09 PM
Jvenne86
17
Mar 20, 2007 08:27 PM
vikingsven
Oct 29, 2006 08:28 PM
billygoat02
Dec 30, 2005 09:19 AM
Bobcat698
18
Oct 22, 2005 12:27 PM
