blown motor @ 65000 km (45000 miles)
Old Dec 20, 2008 | 10:08 AM
good ole boy's Avatar
It started a few days ago when I Fired it up and after few minutes it went into High Idle, then the Oil pressure Gauge dropped to zero and the "check gauges"
light came on. So i shut it down and checked the oil , it was fine. I fired it back up and it had full oil pressure again and was fine for the rest of the day.
The Next morning it did the same thing. And I checked the Oil and Restarted it and it was good again for the rest of the day. Then I drove home From Calgary to Saskatoon (About 600 km) and it was good the entire trip. The next morning It did the same thing and I checked the oil and it was good. I started driving down the Hiway to work and about 10km from my house It started knocking.
By the Time I Stopped I was knocking super loud. I shut it down and checked the oil. Now there was None on the Dipstick.
What happened? Oil pump?
So now I am taking all my Preformance Parts off So that I might be able to get warranty. My truck Only has 65000km on it (about 45000 miles)
Do you think I should also put the stock exhaust back on the truck also?
Old Dec 20, 2008 | 10:34 AM
Scotty's Avatar
Top's Younger Twin
If you know the dealer and can discuss this with them...do that first.
Otherwise, if you pull all the stuff off and leave them to possibly read your ECM and see that changes the performance electronics had done...they may get a bit defensive. Make sure you talk to the service mgr only about this and document everything with him/her. Also, determine what it was. I had a motor go on my 04 and it was #5 cyl one exhaust valve dropped. I was out of warranty but I learned that there are several that have had this happen.
Hope it works out for you. Here in Regina, I was documenting my tick and knock well before the engine blew with a dealer...they still ducked out from under the problem because when the engine blew it was at 186,000 KMS even though I was documenting the complaints and visits with the dealer and was assured..."Drive it and when something happens we will fix it." Luckily for you, you are still under that magic 160K on the engine.
Scotty
Old Dec 20, 2008 | 11:25 AM
dslpwr81's Avatar
Magic 160k. Is there something I don't know about the length of the warrent on the motor?
Old Dec 20, 2008 | 11:30 AM
t-boe's Avatar
Did you use a Fram filter?
Old Dec 20, 2008 | 11:37 AM
GreyTD's Avatar
Cummins warranty 100k miles usa = 160k km canada
Old Dec 20, 2008 | 11:44 AM
Yeah I have a Fram Filter. Why?
Old Dec 20, 2008 | 12:01 PM
GreyTD's Avatar
That filter may cause you more grief than the mods. Last I read or heard Fram filters were not on approved list by dodge/cummins. They tend to come apart inside and plug the oil galleys and oil cooling jets under the pistons.
dslpwr81's Avatar
Ok. I figured with you sig location saying UP HERE that it was prob. Canada. I didn't see the Km, just the K.
Old Dec 20, 2008 | 12:02 PM
Should I Put a diffrent Oil filter on before I take It in?
Old Dec 20, 2008 | 12:08 PM
chrigu's Avatar
you change the after how many km?
if fleetguard stratophere on the dodge list?
i use this filter
chris
Old Dec 20, 2008 | 12:09 PM
Where do I find a List of approved Filters?
Old Dec 20, 2008 | 12:12 PM
chrigu's Avatar
wath oil you have?
how many km you change the oil?
Old Dec 20, 2008 | 12:21 PM
t-boe's Avatar
i use this filter
chris
Fleetguard is a Cummins owned company so you're golden.
Old Dec 20, 2008 | 12:31 PM
chrigu's Avatar
ok cool.
i think the last filter i have buy on cummins dealer in my trip to canada.
i have forgotten sorry
Old Dec 20, 2008 | 12:37 PM
GreyTD's Avatar
The only approved oil filters for Dodge's diesel engine are as follows:
Part # Manufactuer
5083285AA Mopar
LF16035 Fleetguard Stratapore
LF3894 Fleetguard Stratapore
LF3972 Fleetguard Cellulose
LF3552 Fleetguard Microglas
LF3959 Fleetguard Cellulose
3937695 Cummins Cellulose
FL896 MotorCraft Cellulose
L45335 Purolator Cellulose
PF1070 AC Delco Cellulose
There maybe more as this list is from 2006 and older.
