Block heater cord routing?
Old Jan 12, 2008 | 06:23 PM
FSTDL's Avatar
I bought the cord for my 07 5.9 and have it connected to the heater but can't quite see where the holes are for the fasteners.Does the cord go under the battery and then forward.Can some one with the factory install please let me know the routing.I did a search and found nothing.
Thanks
Phil
Old Jan 12, 2008 | 06:32 PM
coparam4x4's Avatar
Mine is routed down next to the oil filter to the frame rail then forward underneath the AC compressor to then it's up to you where you want it from there. Mine comes out the bumper and I attached it to the tow hook.
Old Jan 13, 2008 | 09:37 AM
FSTDL's Avatar
Thank you for your quick response.Is yours a factory set up.I was hopeing you could tell me where the retainer clips pop in.There are 3 of them on the cord.
Thanks again
Phil
Old Jan 13, 2008 | 10:45 AM
coparam4x4's Avatar
I put it on myself but it is a factory cord. There are 3 holes down the frame rail below the oil filter that the clips plug into. I will try and get a picture posted here as soon as I can if you still cant find them. You should be able to see them if you are looking up at the oil filter.
Old Jan 13, 2008 | 12:16 PM
FSTDL's Avatar
Got it.I thought it went over to the side and then under the battery.
Pretty simple.
Thank you very much for your quick response.
Phil
Old Jan 13, 2008 | 02:44 PM
shep1's Avatar
Mind also has clip on the front of the support bracket right behind the passenger side grill, so it holds the cord right next to the plug end. Keeps it out of the way and also protects it from the road slop. Mine was factory installed.
rjm022
Dec 11, 2019 09:17 PM
guzzirider
46
Oct 22, 2009 06:22 AM
Timmer
18
Dec 28, 2006 07:43 PM
Mallard
17
Dec 19, 2003 09:19 AM
mitchkim
36
Oct 28, 2003 04:18 PM
