block heater?
Old Nov 5, 2007 | 09:14 PM
zbob's Avatar
block heater?
Whats the minimum plug in time to get to max temp on the block heater???
Old Nov 5, 2007 | 09:29 PM
jamesbfishin's Avatar
I've always gotten best results with a minimum of 3 hrs, but I leave mine plugged in all night from when I go to bed till I get up to go to work.
Where are you from, up north it might take a bit longer.
Old Nov 6, 2007 | 06:02 AM
zbob's Avatar
NW Colorado, were already down in low teens overnight.
Old Nov 6, 2007 | 06:18 AM
Hvytrkmech's Avatar
I also leave mine plugged in all night, low to mid 20's over here now.
Old Nov 6, 2007 | 07:14 AM
Pav1973's Avatar
All night here,I am going to get a timer though and set it for 3 hrs before I need it but being retired thats more guess work
On the flip side the only reason I use it is becuse I love having the warm air right after I start it up.
Pav
Old Nov 6, 2007 | 01:31 PM
Texasimport's Avatar
On my side of the hill I set the timer for 2 hours before I go. . .that worked well all winter last year.
Old Nov 6, 2007 | 02:25 PM
DodgemnLeavem's Avatar
Cool
2 hrs here in the cold season -20 -40 below wont even heat the front part of the head.. it takes at least 6 hours to even heat the head to feel any warmth from it.. I've got two oil pan heaters 200 watts each one on each side of the oil drain plug. plus the block heater, and a battery trickle charger. and a transmission pan heater 100 watts. altogether!! that will heat her up at -25 in about 4 hours ready to drive.
you guys have it way easy..
last year I wanted to see how cold my engine would start up. I found that it will start right down to -29below once it hit -31 it wouldnt start it did try to fire but just too cold to get her going.. I stopped didnt wanna kill my starter or anything else.
plugged her in at about 8 or 9 am, and by 3pm that day I was able to start it up and go to town.
Old Nov 6, 2007 | 07:20 PM
zbob's Avatar
we'll, I guess a small electric bill hike for pluggin in overnight is cheap insurance to insure morning start up.thanks guys
Old Nov 7, 2007 | 03:25 PM
DBLR's Avatar
I never plug mine in until it gets down to or below zero. I only plug it in for 3 hours an by the time I back it out of the garage, warm it up for 2 minutes, drive 6 blocks through town to the Hwy I can have 60 degree heat coming from the heater vents. I also have a Dodge winter front that I use but not until it stays below 40 degrees in the daytime.
Old Nov 10, 2007 | 12:45 AM
Yeah Ive got a custom made weather front too Ive had it on since near the end of september Ill have it on till at least first part of April. LOL
LOOOOOng winter season here..
rjm022
Dec 11, 2019 09:17 PM
SpeedyWS6
15
Feb 2, 2011 07:22 PM
supersonictoys
Nov 8, 2008 09:17 PM
modiesel
Mar 7, 2008 10:44 AM
Reelay
Dec 1, 2005 06:14 PM
