big problem
Old Sep 25, 2014 | 10:54 AM
dirkdriller's Avatar
big problem
03 ram 2500 with p0341. Wont start at all, but keeps setting this code. Ran all tests, swapped sensors..crank and cam with no change. Ended up replacing the ecm per test but still no start. Can see rpm signal from sensors. I cracked injector lines. Usually the engine will start when this is done on other engines, but not on this one. This leads me to believe the injection pump is not supplying enough fuel. Fuel pressure per scanner is 5500 psi. I need help on this one. Would code set due to no start condition?
Old Sep 26, 2014 | 01:56 PM
Thanks to all who chimed in. I figured it out.
Old Sep 26, 2014 | 02:00 PM
rockcrawler304's Avatar
So what was the problem?
Old Sep 26, 2014 | 02:54 PM
steelblitzkrieg's Avatar
DTR Detective
Sometimes you're better off posting these things in the emergency forum. One day with no response out here isn't unheard of. Hey it's free...
I emailed a bike manufacturer about a problem I was experiencing, it took a month for them to respond. I told them I threw the bike away and purchased a different brand, they responded with asking me to review their customer service.
Old Sep 26, 2014 | 08:18 PM
BigIron70's Avatar
Cummins Guru
Cracking a fuel line on a common rail diesel can be very dangerous. Fuel pressure will go to max 25000 psi and can inject into your skin, could be fatal.
http://www.ncbi.nlm.nih.gov/pmc/articles/PMC2532970/
As for your no start problem glad you figured it out.
JSCumms2000
20
May 6, 2007 02:14 PM
Mexstan
Sep 16, 2006 05:29 PM
boiler-rat
Jan 16, 2006 03:11 PM
Dieseldude4x4
Oct 17, 2004 11:07 PM
Shaders 24v
Aug 11, 2003 10:18 AM
