Battery Load Tester
Old May 27, 2011 | 12:45 PM
justen920's Avatar
Battery Load Tester
Will a 100 amp load tester (Harbor Freight) be big enough to test my batteries? Or should I just take it to Autozone and trust them to do it right? I think my batteries are getting worn out.
Old May 29, 2011 | 05:22 AM
papaduck's Avatar
I had 2 batterys that I was shure were good, took to Autozone to have tested while they were out of the vehicle. They said the batterys were bad. Both were holding 12.8 volts before the test and after. A hydrometer test also showed they were fully charged after the Autozone test that puts a load on the batterys.
My point is, I don't believe every thing I am told. Must see for my self. I would trust the Harber Frieght tester over someone else that might not be very well trained to do the testing.
Old May 29, 2011 | 08:50 AM
carl48's Avatar
just check them one at a time
Old May 29, 2011 | 01:21 PM
justen920's Avatar
thanks, will do.
Old May 30, 2011 | 06:55 PM
wellmax's Avatar
expanding on carl48 reply,
do you have to disconnect the battery to test the battery since the two are hooked together?
Old May 30, 2011 | 07:32 PM
papaduck's Avatar
Yes, disconnect the batterys from each other. Take the cables off one post of one battery and then you can test each battery, but I would want to disconnect the ground on both batterys to insure protection of the electrical circuits that are connected to the batterys.
Old May 30, 2011 | 10:33 PM
wellmax's Avatar
Thanks, will do that,
really did not know how to check them with the duel setup.
2005 model 2500 diesel.
Old May 31, 2011 | 11:17 PM
quadman20's Avatar
If you want to a good test charge both till they green out separately then test with load tester separately as well and you will see if one is better then the other.
Dane
Jan 16, 2013 09:52 AM
Firstgenfanatic
Apr 10, 2008 12:24 PM
carwash
Sep 12, 2007 11:39 AM
BearKiller
Aug 12, 2007 07:19 PM
97CTD
Apr 4, 2003 04:14 PM
