Battery fried, alternator putting out 19volts, dash gauge showing 11volts???
Old Feb 22, 2014 | 06:46 AM
  #31
Shorts's Avatar
Look for bulging at the ends usually. If not you can slit the casing with a razor blade and peel it back. If it is clean just put he casing back up and use a good electrical tape to re=seal the slit part.
Ah ok. That's what I pictured but wasn't sure. Thanks.
Originally Posted by Dr.Dizzle
In addition to slicing the rubber sheathing on the crossover cable,you can check the continuity or resistance. You can place a meter on both ends with one side disconnected and wiggle the cable. Another method is to check the flexibility of the cable. If the corrosion migrates into the cable, it will cause the corroded portion to become stiff. The stiff cable is typically near the cable ends of course.
That is my first method there. Several years ago when building my motorcycle I had a ton of electrical/control button work. Against my wishes my multimeter and I became best friends and now I'm pretty decent at using it.
NoSparkplugs
17
May 17, 2009 10:36 PM
Fronty Owner
Apr 21, 2008 09:43 PM
aggieredneck12
Mar 4, 2008 08:54 PM
barryp
Oct 15, 2007 07:27 PM
Katmandu
Jul 12, 2006 07:56 AM
