Ball Joint Help
Old Oct 30, 2008 | 10:36 AM
WhozNxtLS1's Avatar
Ball Joint Help
Well anyways, I have a 2005 model CTD quad cab short bed and I think it might be time to do a little maint.
I have 66,000 miles on the truck, and haven't check but I'm sure the ball joints are bad. When my truck was brought into the shop to do an alignment they told me I had a bad p/s tie rod end. I think what I'm going to do is the ball jonts, and the tie rod end. I'm sure the ball joints are bad as it's the MOST common problem on this truck.
My dilema. What's best. What should I be looking at in terms of ball joints. Should I need the upper and lower for both sides? I see some sets are $550.00 and I won't spend that much on ball joints.
Any help is appreciated
Thanks.
Chris
Old Oct 30, 2008 | 11:33 AM
woodzy's Avatar
You might as well do all four bj's since you'll have it apart. At $550 I'm assuming that was thru the dealer? If I remember right I picked mine up at napa for under 300 for all four.
Old Oct 30, 2008 | 03:20 PM
WhozNxtLS1's Avatar
$550.00 were quotes for aftermarket uppers I was seeing on here.
Also, it's certain. I took it into the dealer today for service and had my mechanic take a look into it. Def. the upper ball joints are toast. I'll replace all four and I'll do it myself, just trying to get a good price, and a good product.
Old Oct 30, 2008 | 03:28 PM
Danderson's Avatar
Do the '08 steering upgrade if you're going to do the tie rods. Dodge has superceded the parts for a good upgrade.
Old Oct 30, 2008 | 03:37 PM
WhozNxtLS1's Avatar
Hmmmm 08 steering upgrade. Any info on this?
Old Oct 30, 2008 | 06:36 PM
WhozNxtLS1's Avatar
Hookay so, Carli ball joints look sick, but $550.00 for just uppers =/. Moog ones are $117 for one???? I need some help here. I need to know the BEST place to get good solid ball joints for a good price.
Old Nov 1, 2008 | 10:02 AM
The Tank's Avatar
I got mine from napa for 89 a piece,
Old Nov 1, 2008 | 10:26 AM
2500's Avatar
scored a new set of four ball joints (with grease zerts) off craigslist for $50
Old Nov 2, 2008 | 09:22 PM
Halibrand's Avatar
If you buy the Carli joints, they'll more than likely outlast the truck. Replace them with stock bj's and you will be replacing them again in the near future.
Old Nov 3, 2008 | 08:46 PM
MR. GADGET's Avatar
Thats about the same as what they got me for and it was a 6-7 hr job to do the work.
72dart
Jun 19, 2012 10:42 PM
Wulzcat
Dec 19, 2009 05:15 PM
wcbcruzer
22
Apr 30, 2008 06:58 PM
FDC
Jul 16, 2007 12:51 PM
Treangen
May 7, 2007 03:10 PM
