Ball Joint Club
Old Jan 8, 2008 | 10:19 AM
ssandlin's Avatar
Ball Joint Club
This was one club I was hoping to avoid. Found out this morning that all four are bad at 47,000 miles, of which 46,500 would be all on pavement. I'm going back with greasable ones that will hopefully last at least twice that long. My wallet just got a lot lighter, thanks Dodge.
Old Jan 8, 2008 | 11:09 AM
John Faughn's Avatar
I read a post about those the other day , sounds like you need to put a 2nd gen axial in its place .
The post talked about how they change the geometry , the 2 joints no longer line up [ real pane in the *** for getting press in there ] and because of that all the weight is on the lower ball joint .
I do not remember where I read it , other wise I would link you to it .
Old Jan 8, 2008 | 11:15 AM
carwash's Avatar
Just for future info, what kind of cost are you looking at for the dealer/garage to do it if you are not doing them yourself.
Old Jan 8, 2008 | 12:28 PM
ssandlin's Avatar
I'm not going back to the dealer because they'd just replace them with what I had. I'm using a local garage whom I trust, with material and labor, drive out is $1,100.00. Thanks again, Dodge.
Old Jan 8, 2008 | 12:40 PM
tool's Avatar
What is the factory warranty on Ball Joints?
Old Jan 8, 2008 | 12:51 PM
I did them for a friend last summer for $300 , he said that he found a shop to do for about $600 .
When I had my last shop , I remember doing a chev for about $700 , not including parts .
One of the issues is if you dig into that deep , saving future costs by doing axial seals & u-joints is something to take into consideration , anytime you open up something next to an other repair you may want to take advantage of being that deep into it .
Old Jan 8, 2008 | 01:54 PM
BRayls's Avatar
it is not hard to drill them and install zirks. very viable option for those that have newer trucks.
Old Jan 8, 2008 | 04:09 PM
ssandlin's Avatar
That would be 3 years/36,000 miles, unless you buy an extended plan that would cover the ball joints.
Old Jan 8, 2008 | 04:54 PM
rjm022's Avatar
joined this club, last june at 63,000 ,miles. i also had a bad tie rod and wheel bearing. at this point i went ahead and replaced the whole entire front end-including getting rid of the hub assemblies!!
Old Jan 8, 2008 | 09:49 PM
upjeeper's Avatar
is there a write up on this? it sounds like a great idea
i'd be concerned about getting metal shavings from drill or tapping the hole inside there
Old Jan 9, 2008 | 05:21 AM
BRayls's Avatar
grease the drill bit to help with metal contamination. I have drilled them for years. remember grease good, water bad. the engineers forgot that.
Old Jan 9, 2008 | 09:40 AM
Patriot2500's Avatar
I joined the club at 66k last year. I replaced u-joints, upper and lower ball joints, and hub bearings with Moog stuff.
Old Jan 9, 2008 | 05:37 PM
sallyman1's Avatar
so there is seals when u r in that far? i asked on about 40 posts and no one could answer my question. im doing ball joints myslef and bought them and the tool from rockauto.com . i asked people on here if ill need seals or anything because i wanna get all parts i need b4 i do work so truck isnt apart for weeks on end waiting for parts. no one seems to know if theres seals that you fiddle with or not?
Old Jan 10, 2008 | 08:43 PM
sallyman1's Avatar
ttt any1. any seals that need replacing when im in there?
Old Jan 11, 2008 | 05:32 AM
BRayls's Avatar
axle seal if its leaking.
