Baldwin PF7977 5 Micron fuel filter for factory location...
Old Mar 12, 2007 | 06:39 PM
Spooler's Avatar
Just want to make sure everyone knows that Baldwin has a filter that is spec'd for the Bosch fuel injection system.
1-2 Micron Nominal
5 Micron to absolute at a 98.75% efficiency
Thank Hounddog he found it.........
I order 2 today for myself....
Old Mar 12, 2007 | 06:42 PM
53 willys's Avatar
where can a guy pick some up at????
Old Mar 12, 2007 | 06:55 PM
Spooler's Avatar
At a Baldwin dealer. Since we have alot of trucks running through Savannah due to the port it didn't take long to find. Heck, give Fleetpride a call in Savannah,Ga. or Baldwin themselves.
Baldwin- 1-800-822-5394
Old Mar 12, 2007 | 07:07 PM
53 willys's Avatar
cool thanks I will order some locally tomorrow
this is great news
Old Mar 12, 2007 | 07:38 PM
MikeyB's Avatar
Associated Diesel has the PF7977 for $13.36 each.
http://www.adiesel.com
MikeyB
Old Mar 12, 2007 | 10:40 PM
06megacabman's Avatar
Another place from another thread. Seems like ok prices.
www.scheiddiesel.com
Old Mar 13, 2007 | 12:59 AM
Hounddog's Avatar
Actually my neighbor found them.
Old Mar 13, 2007 | 01:00 AM
53 willys's Avatar
did you say you called Baldwin to make sure it was a 5 micron???
Old Mar 13, 2007 | 01:15 AM
Hounddog's Avatar
Sure did and had them fax me the spec sheet.
Old Mar 13, 2007 | 01:59 AM
53 willys's Avatar
Thanks
Old Mar 13, 2007 | 05:23 AM
HorseHauler's Avatar
I know this has been discussed b4, and I'm pretty sure it's fine but, will the stock in-tank lift pump be ok with a 5 micron filter?
Old Mar 13, 2007 | 06:01 AM
Hounddog's Avatar
One I would hope Baldwin took this into consideration before production.My neighbor has a 05 dually with about 120k on it,bone stock except for a Rokktech crank sensor.Has always run 10 micron filters.He changed to the 5 micron Baldwin and just did some horse hauling(pulls about 9k loaded) from here(Ga.)to Ok.and around a few other states totaling about 3k in 4 days with no issues.
Old Mar 13, 2007 | 09:26 AM
surfram's Avatar
I would think the max service life would be under 10,000 miles on a 5 micron filter, depending on fuel quality.
Old Mar 13, 2007 | 09:32 AM
Pooter's Avatar
Cool deal, price isnt too bad either....
Old Mar 13, 2007 | 10:01 AM
Spooler's Avatar
I agree it probably will be lower but you will save your injectors from the added wear so that is a good thing. I would rather the filter catch the junk and change it more frequent. It also has the same flow rating at 5 microns so I don't see any negative issues on the LP.
