Bad/Leaking Injectors???
Old Jun 24, 2007 | 06:11 PM
Pooter's Avatar
Red face Bad/Leaking Injectors???
Just wondering what the symptoms are...
I know to check the oil level, which mine seems high, but no smell of diesel at all.(Which I always thought was a sign of it)
Also too, fuel mileage has decreased, and over the past two months has gotten worse and worse with each fillup, same driving habits.
Sitting on 12.9mpg right now(hand calculated)
Any help would be appreciated, or if anyone knows anyone in the DFW area to have it checked out.
Thanks
Old Jun 24, 2007 | 07:54 PM
Rpainter's Avatar
did you check the oil level in the morning before start up? One way I know to check if th einjector is leaking in the oil is replace fuel filter and fill the canister up with fuel treatment run truck shut off and check oil if it smells like treatment bad injector
Old Jun 24, 2007 | 08:00 PM
gafirefighter's Avatar
when the #2 injector went out on mine it started running like crap cold and blowing A LOT of white smoke at start up. I checked the oil several times and it was never making any oil. my $.02
Old Jun 24, 2007 | 09:02 PM
Pooter's Avatar
I may give it a shot, but I just replaced the fuel filter, and dont have any more spares at the moment.
This has been more of a ongoing issue, the oil level was fine before, but after the last tank getting some pretty cruddy mpg, I checked the oil level, and its a bit high. The fuel mileage has been dropping over the past two months, from 14/15mpg, to not breaking 13, just got 12.9 last tank.
GAFF, I dont have any smoke issues, non at startup, and nothing but coal black rolling into it on the highway, havent seen any whitesmoke.
Are the rumors true of being able to smell diesel in the oil?
Old Jun 24, 2007 | 09:09 PM
Rpainter's Avatar
when my injectors went out I had no white smoke no rough idle idled great no stumbling checked oil due to the fact my manual oil pressure gauge was reading low psi I drained about 6 1/2 gallons of oil and fuel out of the crankcase
Old Jun 25, 2007 | 08:47 AM
Matt S's Avatar
It depends on the amount in the crankcase but yes you could smell it if it were in there.
Old Jun 25, 2007 | 09:30 AM
Sevir's Avatar
The O-reillys auto store here has a L/O viscosity test for rent. Might want to call around to see if a auto store around you has one for rent. Then you can test to see if you have too much F/O dilution. Anything over 5% means there is a leak. but you will see anywhere from .5% - 2%
Old Jun 25, 2007 | 11:33 AM
Texasimport's Avatar
Last month I was getting a little white in the mornings and a bit of a rough idle. . . It turned out the perhaps a dirty injector not a bad one. . .I don't drive hard during my commutes. . .so the recent camping trip 700miles round trip towing a 7K trailer was just the ticket. . .mileage went from 18.5 back up to 21 and no mornings with rough idle or smoke since then. . .
It must be true. . . .you gotta work these motors. . . .
Old Jun 25, 2007 | 04:24 PM
8mpg's Avatar
Pooter was telling me that the oil level is up 1-2" on the dipstick..Im saying bad injector.
Old Jun 25, 2007 | 04:55 PM
Pooter's Avatar
Probably taking it in tomorrow, give me a shout!
Old Jun 25, 2007 | 10:12 PM
wreedCTD's Avatar
Thanks
Did you MPG idiot gauge also show the decrease in mileage? just wondering.
i would run some power service thru your truck every once in a while if you dont work it hard.
Old Jun 25, 2007 | 10:29 PM
Pooter's Avatar
Yeah, slightly less on the overhead, but way less hand calculated
I was averaging 14/15, then slowly went downhill, last tank was 12.9mpg.
I run power service every tank(8oz) and occasionally tcw-3 2 cycle.(just a few oz at a time)
Old Jun 26, 2007 | 10:53 AM
Pooter's Avatar
Truck is in the shop.
<-Fingers crossed
Old Jun 27, 2007 | 02:02 PM
Pooter's Avatar
Well, they say the injectors are fine...
I really dont see how, but oh well. At least when they saw the ECM, they didnt report it to DC.
Should be picking up the truck tonight, guess ill see if the fuel mileage miraculously improves...
If not, '07 5.9 6spd on the way.
quick1sr
Sep 4, 2008 05:51 PM
65fury
25
Apr 6, 2007 08:16 AM
Buckshotram
Jan 9, 2006 09:27 AM
C Pierce
Mar 21, 2005 08:41 AM
BIGOKIE
Jul 21, 2004 05:53 PM
