Bad Injectors?
Old Oct 25, 2011 | 09:22 PM
Jdub's Avatar
Question Bad Injectors?
Truck has been taking longer to start than normal. We had some temps in the upper 40's / low 50's a few nights ago and it wouldn’t start at all. Finally around noon after warming up I finally got it to start. It has also shut off on me a few different times; each time was after idling for several minutes or more or after long drives. I would stop and it would idle ok, then you give it some pedal and it bogs down and cuts off, but always fired right back up.
I have no white smoke at start up that I've noticed. I did have a buddy check for codes and I'm getting a grid heater problem, which after thinking about it I don't believe it cycled on the other night when it was cold. Normally the voltage drops and the dome light dims when it kicks on.
Even with the grid heater not working, that shouldn't cause a no start with temps only in the upper 40's would it? From what I’ve found searching past posts it sounds like an injector issue?
Any advice would be appreciated, or any other things I should check would be appreciated.
Old Oct 26, 2011 | 07:44 AM
jhenson's Avatar
Check fuel filter first and then verify that the LP is supplying adequate fuel.
quick1sr
Sep 4, 2008 05:51 PM
65fury
25
Apr 6, 2007 08:16 AM
Buckshotram
Jan 9, 2006 09:27 AM
C Pierce
Mar 21, 2005 08:41 AM
BIGOKIE
Jul 21, 2004 05:53 PM
