Anyone seen a serial number like this?
Old 03-12-2019, 05:39 PM
Green_Machine's Avatar
Out of curiosity I started to match up the old engine with the ecm number and the truck vin. Thanks to Cummins Quickserv mobile I've verified the ecm belongs to the truck, and the engine esn should be 57006796.
I bought this truck used, and this engine has never had the valve cover sticker. Finally got around to checking out the block esn by the water pump neck and this is what I found:
Large Font: 2LB003220 5with box around it, then B, then some circle with a line through it vertically
Small font: 3970792
Neither of these match the spec for Dodge Cummins as far as I've researched (8 numbers). Anyone have a clue where this thing is from??
Bushy
07-16-2005 01:50 PM
Mikedeere
02-21-2005 08:52 AM
A-Poc
01-23-2005 07:47 AM
futch
10-28-2004 05:44 PM
FANZDSLPWR
06-05-2004 11:32 AM
Quick Reply: Anyone seen a serial number like this?
