serial number
Old Feb 19, 2005 | 03:16 PM
Mikedeere's Avatar
serial number
I have 98.5 , I`m thinking about 275`s. I was reading about on the ones before a certain s/n you need to buy a connector tube kit?? Where is the # located???
Old Feb 20, 2005 | 08:14 AM
Mikedeere's Avatar
Also, If I need the connector tube kit. Is that just for the 275`s ? I assume it is for all injectors? And where do they go? Help!!!!
Old Feb 20, 2005 | 11:14 PM
joefarmer's Avatar
I'm really not sure why you'd need different connector tubes. The engine serial number is on the side of the ECM (driverside, centered on the side of the block). It should start with 56 or 53. Your injector supplier should be aware if you need special parts to install them. If they don't know, I'd recommend a different supplier.
brandon.
Old Feb 21, 2005 | 08:52 AM
Mikedeere's Avatar
I don`t know either, but if you look at the price list Pier`s Diesel for instance, it has them listed, so it has me confused(don`t take much) but I will call them . I`m sure they can tell me if I will have to spend the extra bucks Thanks for the responce.
Big Deezul
Jul 26, 2005 07:55 PM
Bushy
Jul 16, 2005 01:50 PM
A-Poc
Jan 23, 2005 07:47 AM
futch
Oct 28, 2004 05:44 PM
FANZDSLPWR
Jun 5, 2004 11:32 AM
