Help!! Fuel pressure issues
Old Mar 14, 2019 | 12:55 PM
Nic88g's Avatar
Hey guys need some help and ideas
i have an issue with my truck not making fuel pressure it gets to around 18,000rail on wide open throttle
i would expect that when I floor it that the frp should just straight to around 26,000 ish
mine seems to slowly creep up and only after holding wot for a while will it make it to 18,000
the truck has edge tuner
60hp injectors
bd diesels 150lph lift pump
The truck starts and runs great idles no worries and seems to do everything smoothly just lacking some power.
i have changed fuel filter it was clean
checked voltage to lift pump 14.4volts
changed fpr relief valve and for testing it has a plug in it for now
no fuel in the oil and starts and runs clean so guessing injectors are ok
they are reasonably new
not sure what to check or look at next
is there any in line filters or any gauze filters in the banjos or anything?
any help appreciated
thanks in advance!!!
Puke
27
Feb 3, 2021 01:21 PM
dodgeguy71
17
Jan 19, 2012 12:52 AM
RyeThomas
Jun 4, 2009 06:11 PM
Mr Bee
May 20, 2009 10:55 AM
HydraulicGuy
Feb 9, 2006 09:53 PM
