Any body service this?
Old Feb 22, 2005 | 05:30 PM
Rob's Red Ram's Avatar
Question Any body service this?
On my 05 there is this decal under the hood. Has anyone serviced the front driveshaft like it say's on the decal.And how do You grease it with a needle,what kind of grease.Thank's Rob.
Old Feb 22, 2005 | 06:14 PM
N.Johnson's Avatar
No way they finally put a zert (grease nipple) on the front u-joint? If DC went to the trouble and paper work there should be a zert at the cross of the joint. No this is to good to be true...... internet?
Old Feb 22, 2005 | 06:33 PM
Mark Thomas's Avatar
I say photo chop
Old Feb 22, 2005 | 08:17 PM
Blue600's Avatar
Re: Any body service this?
My old Jeep trucks had a grease cup in the CV joint. You had to use a grease needle in the gun to service it and it was a pain. You had to get the driveshaft just right to get the needle in the cup. As for the u-joints you had to use the needle also. Too tight of an angle to get a regular grease tube in there.
Old Feb 22, 2005 | 10:13 PM
Hemi Cat's Avatar
Yes. Use a needle point adapter on your grease gun. Mine is a lincoln. Just use regular ep chassis grease or better.
Old Feb 23, 2005 | 01:33 AM
runamuk's Avatar
I'll just replace mine with real u-joints thanx
Trooperthorn
Jan 7, 2011 12:55 AM
jj3500
Jul 12, 2009 03:59 PM
Greed 93
May 22, 2009 09:15 AM
wcialrlter
Mar 7, 2009 07:15 PM
