Another U-Joint
Another U-Joint
Just had another U-joint go on me. Its the one in the front drive shaft so I baiscally lost my 4X4. Does anyone have a part number for a front drive shaft u-joint from NAPA or somewhere else that I might not need to make a special order. Its -20 outside and 3 feet of snow
, and I don't feel comfortable gatting another dealer u-joint. Thanks in advance.
Originally Posted by sherman
Where is Buckingham in Quebec?
It is about 10 miles east of Ottawa, Canada. Anyways I found some greasable ujoints. Made by Precision. The two by the T-case have part number 354, and the one by the diff is 534G.
I've noticed that the dealers don't always give you OEM but will charge you OEM price!!
Wherever you get it, get a spicer. You can find them at driveline/friction shops, napa might have them.
Check to see if your existing joint is a spicer, if it is, I would suggest the "Brute Force" by spicer. No grease zurk, and solid all the way through. You can't service it, but you get a lot more strength.
Good luck... I don't blame you for not wanting to get burned again. Tis not the season to be wrench'n... too **** cold
72dart
Jun 19, 2012 10:42 PM
wcbcruzer
22
Apr 30, 2008 06:58 PM
FDC
Jul 16, 2007 12:51 PM
Treangen
May 7, 2007 03:10 PM
Jezzhuntin
Aug 25, 2006 02:51 PM
