Another P0192 Code question
Old Sep 21, 2009 | 05:35 PM
rockcrawler304's Avatar
I did some searching but did not find my answer.
I was driving home today and this little ricer started to mess with me, so I showed him how fast a 7500lb diesel truck was! Didn't take him long to realize he would not win.
After one good hard run I noticed the CEL came on. I returned to cruising speed until I could get off the freeway at my exit. Truck still runs fine. I even got on it a few short bursts with no problem. Will this code clear itself with a few key cycles?
Also my truck has no power mods so why would I even get this code? I have run it pretty hard several times with no issues.
Old Sep 21, 2009 | 05:54 PM
madhat's Avatar
Administrator/Jarhead
P0192 Fuel Pressure Sensor Voltage Too Low
Could be that your stock lift pump is getting weak, and not providing full fuel pressure at WOT. Do you have a FP and RP gauge?
Old Sep 21, 2009 | 05:58 PM
Unfortunately no gauges yet. I know I know
Old Sep 21, 2009 | 06:21 PM
madhat's Avatar
That would be the first order of business. It could be any number of things, from a bad connection, faulty sensor, failing batteries, or fuel pump. Gotta have more clues!
Old Sep 21, 2009 | 06:25 PM
I wish I had more info.
If it was a quick drop in voltage to the sensor, will it clear itself or will I need to have the code cleared? Any ideas?
I guess I will be getting gauges sooner that I thought! And with money being an issue at times here, would a FP gauge be the first to buy versus the RP? Sine I do not suspect any issues at this time from the CP3.
Old Sep 21, 2009 | 06:38 PM
madhat's Avatar
It will clear after a certain number of key cycles. I don't know the exact number.
Old Sep 21, 2009 | 06:44 PM
Thanks so far with the help Mark!
Old Sep 22, 2009 | 03:41 PM
madhat's Avatar
Anytime...
Old Sep 22, 2009 | 09:44 PM
Looks like 5 key cycles and the light goes off
sallyman1
13
May 21, 2008 10:38 PM
Secondrate
Jan 24, 2008 09:07 AM
Dieselhed
Dec 29, 2007 07:11 PM
