Another A/C thread
Old Aug 13, 2011 | 12:49 AM
tallboy's Avatar
Originally Posted by Hintonc393
If you can, you need to get a set of gauges hooked to the system. That will tell us so much more about what is going on. Be sure to include what the out side air temp and the inside air temp is. The past times that you have had it charged has someone be putting a vacuum on it or have you just been putting refrigerant in?
The past times were at a shop, they evacuated the refrigerant, I swapped out High pressure switch, then they added it back in. They then tested for leaks and found none. It had held the same amount for the past 6 weeks, so that isn't the problem. Looks like it is going to the shop, I've had enough of it on my own. I'll post when I get it figured out.
Thanks guys
Old Aug 13, 2011 | 07:03 AM
Hintonc393's Avatar
The pressures tell you more than just the level of refrigerant in the system, they are very diagnostically useful. But I understand, you have had as much as you can take trying to fix it yourself. Take it to a good shop that knows what they are doing and you should be fine.
schoust
Oct 21, 2009 10:09 AM
Jezzhuntin
Aug 25, 2006 02:51 PM
HaulinRoans
Mar 23, 2004 08:18 AM
TX Ram
Apr 11, 2003 05:56 PM
