Another Auto to Manual Thread
My auto 48re told me yesterday that it no longer wishes to be part of the cummins world. Second gear disappeared. Last night we pulled it out and got the thinking. Looks like it would not take much to bolt in a six speed. Clutch pedal appears to be the biggest issue. Would the computer be a problem?
You need trans, Tcase(or just input shaft for tcase), bellhousing/starter shim plate, clutch/flywheel, hydraulics(master/slave cylinders), ecm, abs ecm(vin locked to ecm), engine harness, fuse harness that goes into the cab(for the clutch switch), and then you need the brake pedal and clutch pedal and clips that hold them on. Also need driveshafts front/rear.(6" longer front, 6" shorter rear I believe, but thats on a QB/SB truck)
The ecm/harness needs to be from the same year truck. Trans crossmember is the same.
Ive researched it a little bit, but havent found all the parts I need off one truck and I dont want to go piecing it all together(cost more)
call this guy he deals in 3rd gen trucks from ins auctions. tom gonzales 210 354 5229. he's where i got the stuff i needed when i swapped my nv45 for an nv56 on my 03 that i had
Jezzhuntin
Aug 25, 2006 02:51 PM
ezdemon72
14
Jul 29, 2005 10:05 AM
ouchman
May 30, 2005 11:53 PM
soundbrz
Nov 7, 2002 03:04 PM
