another auto to manual question..
Old Mar 3, 2007 | 01:52 PM
mx684's Avatar
still searching for all the things i need, i was told that the chip would still work with the manual in...however i got to reading about the differnt turbos between autos and manuals....will that cause any problems for me if im running my stock turbo from the auto, with a manual trans???? i would like to upgrade eventually anyways, but id like to get the manual swap all done and working before i spend any more money on other things..unless that turbo will give me problems and it has to be done id like to find out before tearing it apart...thanks
Old Mar 3, 2007 | 02:05 PM
torquefan's Avatar
I would think your stock HY35 would work just fine with only mild performance increases. It would be easier to monitor with gauges though. If you decide to upgrade the performance any further, do the turbo first, but I can't see the transmission conversion hurting anything.
Old Mar 3, 2007 | 02:21 PM
mx684's Avatar
alrighty, thats what i was needing to know,, thanks alot
Old Mar 12, 2007 | 10:49 PM
rjordan's Avatar
what all is needed to be done to swap out an auto in an 02 for a nv5600 4x4, im looking at doing this in my 02 and was just wondering.
Old Mar 13, 2007 | 01:04 PM
mx684's Avatar
You need the tranny,clutch,clutch master cylinder/lines. pedals, shifter, shifter console, hole in floor. correct length drive shafts, and if its a 4x4 you will need to change the input shaft in the transfer case. that pretty much covers it i believe...i was told the bellhousing off the auto will work, and was also told that the ecm and pcm will be fine. that subject has been argued alot but i talked to a guy on here that did the swap to a 24 valve and he said his worked fine without..so thats what im going by...
andyboland
Mar 15, 2009 10:41 AM
Jezzhuntin
Aug 25, 2006 02:51 PM
ezdemon72
14
Jul 29, 2005 10:05 AM
ouchman
May 30, 2005 11:53 PM
soundbrz
Nov 7, 2002 03:04 PM
