Almost crashed!!!!
Old Mar 12, 2010 | 05:06 PM
Lost Lake's Avatar
Originally Posted by thenrie
- Lost Lake said a load in the bed "decreases caster". Question on that.
I believe positive caster is forward of the axle vertical centerline and negative caster is aft of the vertical centerline. Since negative caster is what we want (makes the wheels follow better, more stable), doesn't a load in the bed, which lowers the rear of the truck, effectively increase the desirable negative caster (eg increase from -1.5 to -2.5 degrees)? Or do I have it backwards?
Positive caster makes the wheels track ahead. Lowering the rear should increase positive caster. I stand corrected. Don't know where I got that thought.....
Old Mar 12, 2010 | 05:11 PM
Lost Lake's Avatar
Originally Posted by Fisherguy
Changing the damper is not a cure, it only masks the problem.
Take it in and get the front end checked, check the track bar bushings closely, try someone else's tires and wheels.
Now just to dispel rumors and keep others from suffering DW, I pass this along.
I had DW and I took my truck in to be checked several times. The caster was excessive, right on the edge of where Dodge specified it. 4.6 degrees positive on the right, 4.5 on the left. That is good, it helps prevent DW.
The track bar and bushings checked out fine. The ball joints and shocks were great. Steering was perfect. Nothing wrong anywhere.
I changed the damper and it was gone.
Old Mar 12, 2010 | 05:32 PM
Fisherguy's Avatar
The damper just covered it up, something was wrong somewhere.
Old Mar 12, 2010 | 06:12 PM
thenrie's Avatar
OK, so I have it backwards then. Negative caster is when the turning axis of the wheel (that would be the king pin on a 2wd) is tilted forward of the axle's vertical centerline and positive caster is when the wheel's turning axis is tilted aft of the axle's centerline. Right? So, we want positive caster. So, with a load in the bed, we increase positive caster, which is good. Yes?
Well, then I have to correct my Studebaker story. It had negative caster designed into the front suspension...
After much reading through a several hundred emails that said, "What's that part number again?" and "which damper doesn't work?" I finally figured out what "Death Wobble" is. Wouldn't it be nice if someone were to make a sticky with the basic info as to what it is and how to fix it? Might save a ton of newbie questions like mine on the board. I'm not qualified, knowledgewise, to do it or I would put one together.
Old Mar 12, 2010 | 11:04 PM
Lost Lake's Avatar
Some of the old cars had negative caster to ease the steering forces before power steering, but then they would need constant correction as they went down the road.
Jmac
Jan 17, 2010 02:34 PM
johnzie
Mar 6, 2007 10:49 PM
crobtex
Feb 21, 2006 05:18 PM
MNYPDRBLT
Oct 4, 2004 07:50 PM
BAD HABIT
Mar 9, 2003 02:20 PM
