all done
Old Feb 23, 2008 | 03:52 PM
ian515's Avatar
all done
ok, got the injectors in, everything back together and started her up. how long do most trucks run rough for before they new injectors smooth out? also, when I start driving it, should I run them hard, or take it easy?
Old Feb 23, 2008 | 09:46 PM
rich's Avatar
mine ran smooth when i put them in and i drove it like i normally due
Old Feb 23, 2008 | 11:41 PM
elirandolph's Avatar
how did the install go? No problems?
Old Feb 24, 2008 | 09:48 AM
ian515's Avatar
hahaha, no, there were a few ones, but I got it sorted out in the end. I am concerned though, because this morning I went to start er up and it started fine, but when it kicked into high idle, it was missing a little bit.
Old Feb 24, 2008 | 10:15 AM
Blueboy's Avatar
When I put mine in it took a long time to start, then a lot of white
smoke. I drove it and everything cleared up. Did you adjust your
valves after you put it back together, did you torque everything
to spec.
Old Feb 24, 2008 | 11:08 AM
ian515's Avatar
everything is torqued to spec, didnt adujst the valves, never heard that I needed to do that. when I started it up right after, it was rough and blew white smoke, but after that smoothed out. drove it 5 hours to come home and this morning it was a little rough, but fired right up better than ever at least.
Old Feb 24, 2008 | 06:56 PM
I'm not positive but i think you have to set the valve lash on the exhaust rockers that you had to remove in order to get the injectors out.
Old Feb 24, 2008 | 09:04 PM
ian515's Avatar
it wasnt in the instructions I got online, but I will do it anyway just to be safe, thanks for the heads up.
the intake rockers are the first set right? and exhaust is the one I took off?
Old Feb 24, 2008 | 10:34 PM
OOPS's Avatar
Any time you mess with the valve train you should adjust the valves.
6.7L MegaCab
30
Nov 10, 2011 10:36 PM
pwrtripls1
Jun 6, 2010 10:26 AM
mainer
Oct 23, 2007 02:42 PM
Ramdriver15
Jan 24, 2007 09:33 AM
hellotbone
26
Aug 1, 2003 08:50 AM
