Air lift suspension questions
Old Dec 29, 2006 | 07:08 PM
midwestdually's Avatar
do they make an air bag lift that will lift the truck in both the front and the rear?
are air bag kits only designed to stiffen the truck suspension with a load on it or can they raise the truck as well?
the reason i ask is that i want to still be able to put the truck in the garage (7') but also want a 4-6" lift. i dont pull anything other then a 22' boat that weighs around 7k loaded. is there something out there?
Old Dec 29, 2006 | 07:26 PM
w.tx iceman's Avatar
kelderman airride makes full air ride for 4x4 trucks
Old Dec 29, 2006 | 07:53 PM
wow...them there are expensive!! any other alternatives?
Old Dec 30, 2006 | 12:57 AM
GMScott's Avatar
If you're towing, why would you raise the entire truck?? But to answer your question about lift, I have the Firestone dual control airbag kit on the rear which will lift the rear loaded or not. I put them on cause the rear springs had weakened to the point that no matter what weight trailer I put on the truck it would sit on the helpers and sag.
I actually lowered the rear by removing the spacers under the leafs as I haul various types of 5th wheels which have different size pin boxes and I needed more clearance between the bedrails. I also wanted to avoid having to adjust the 5th wheel hitch height with each different trailer. The 4X4's sit pretty high in the rear stock. Now, I have enough clearance and can raise the rear without worrying about contact on the bedrails.
Mexstan
Apr 16, 2010 03:09 PM
herb
Jul 18, 2008 08:25 AM
Chrisreyn
Jun 13, 2007 12:07 PM
Ramirezh
Mar 29, 2006 02:51 PM
Feb 19, 2003 01:35 PM
