michellens to blame?
Why would the tire be at fault? Wouldn't any other tire at 80 psi do produce the same effect? I do think 80 psi is a bit much in air pressure though. But, it should not have caused a wheel bearing failure. How many miles on the truck?
110,000 miles any tire for that matter. Just took some advice from a few people on the board here.They said to run them at 80 psi to get better milage.Well 8000 miles later bearings are out. Rode terrible and I should have let them down rite away.Like riden on two stones..
my current truck is #14 since '64 and all have ben 2500/3500 with load range "E" [80 psi]. In my business my truck tires stay at 80 psi 24/7. Sounds more like a driving style problem or your particular wheel bearings weren't up to par.
JIM
JIM
I understand that you took some advice but remember, the max pressure on the side of the tire is for the tire not your truck. That tire can be mounted on many different vehicles. Use Dodges recommendations on your door as the start point then taylor it to load and preference. When I worked for Bridgestone/Firestone, I came across this problem all the time. People read the side of the tire and pump away! I had a guy come in once with the center worn to the cords and the rest of the tire looked almost new. He had 55 PSI in them with the car calling for 28. "...but the tire said...."
hovisimo
Feb 17, 2008 11:29 PM
Common
Oct 26, 2006 10:12 PM
