Air filter minder
Old Jun 24, 2003 | 11:00 PM
RLS's Avatar
RLS
Air filter minder
My air filter minder has never moved, 9661 miles. My fuel milage had started to drop off so I opened the air box and the filter looked to be covered with a dark film. The owners manual says not to open the box until the minder pulls down. Does any one else have or have had a defective air filter minder?<br><br>I changed the filter and MPG seem to have come up.
Old Jun 25, 2003 | 04:37 AM
Drafter's Avatar
Re:Air filter minder
With a little over 4,000 mile on mine the filter minder doesn't seem to have moved much or at all. I have not noticed any changes or mileage drops. I attribute this to normally not driving in dusty conditions and just figure that when the filter minder moves it moves and then I will replace. I also figure that the low mileage I have and the driving conditions in which I operate shouldn't make the filter minder move in the first place. Correct me if I'm wrong but I wouldn't worry about it.
Old Jun 25, 2003 | 04:50 AM
Mexstan's Avatar
Mine moved to about 35% from day one. Now I have the Scotty 3 and don't have to worry about it.
Old Jun 25, 2003 | 04:24 PM
cp's Avatar
cp
If your filter minder isn't moving and you are curious if your filter needs changing, the thing to remove is the filter minder itself and test it. That's a less risky maneuver than jacking with the element.<br><br>If the minder seems to work when a vacuum is applied, then temporarily replace it with a gage. Leave the element in place and see if the gage detects restriction. If it does not detect some restriction, that should raise a big, red flag--filters do not filter with no restriction at all.
89dieselkong
Feb 26, 2013 05:02 PM
DennisT
16
Aug 31, 2007 03:09 PM
sjester
Apr 17, 2006 10:06 AM
lukem86
Dec 24, 2005 10:28 AM
royta
Sep 17, 2005 10:25 PM
