air dog noise?
Old Jul 30, 2010 | 06:43 PM
monsteredge's Avatar
air dog noise?
I have an 03 and the lift pump went out about a year ago and I replaced it with an air dog 100. its been getting louder and I replaced both the fuel flter and water seperator filters and checked all the fittings for leaks and its still noisy.. tried calling tech support on this and have got no answer or a return call. any ideas what ese I can try? mods are a smarty jr on level 2 (towing) a cold air intakeand a magnaflow exhaust
Old Jul 31, 2010 | 07:24 AM
tesla440's Avatar
when you have the water seperator off, did you take a look a the screen in the threaded part to make sure that there was no objects in there or plugged? Also you can pull of the back cover of the gear-pump and check the gears to see if there is any wear or dirt in that housing causing it to wine.
Old Jul 31, 2010 | 09:15 AM
is there a certain orer to remove and replace the gearator assembly? i though the instructions said something about that but I cant find them
Old Aug 1, 2010 | 10:51 AM
tesla440's Avatar
There is only a few pieces to the assembly... Cover, screws (4), orings (3 I believe), inner & outer gear pump gears. You just need to make sure that you put the gears back so that they sit even an just a hair back from the cover plate. The trick (which is really isn't tricky at all) is making sure the orings get seated correctly in the groove of the main housing. From there put the cover back on & screw the 4 screws in evenly.
Old Aug 1, 2010 | 11:06 AM
took the cover off no dirt of debres in there and no rub marks on the gears or housing.. is this just gonna be the way it is now? am I doing any harm to the pump or the rest of the fuel system like this??
Old Aug 1, 2010 | 11:21 PM
Sasqoutch's Avatar
My air dog 100 makes noise, can always hear it run. Im writing it off as normal since its been that way from day 1
Equalizer 2
Oct 22, 2009 09:48 PM
duster75
Sep 9, 2009 11:02 PM
trailinone
16
Jun 19, 2009 04:28 PM
herb
Jul 18, 2008 08:25 AM
