AFE and dust?????
AFE and dust?????
Hey guys,
I took the afe filter sock off today to clean it, and took the filter off to take a look at it and noticed a very small amount of dust in the intake tube, it has been 15,000 since I last looked at it, is this a problem is it normal? Will this cause any damage. 15,000 miles ago I switched to the pro-guard 7 filter, with sock on the stage 2 intake system, for about a month I ran the standard filter in the stage 2, thats the one that it came with, I had to order the pro-guard 7 seperate, so maybe the dust came from the original filter I had on the system, anyone had problems with dust with their pro-guard 7? How will I know if any damage is done?
Also I took the piece of rubber out from beside the passenger side radiator, will this cause any harm, I noticed streaks from where a little water/rain had gotten on the sock.
Water is supposed to "bead-up" on the pre-filter (sock) & drain off. Don't know if it actually does do it, though.
If you haven't done an oil change, yet, you may want to get an oil analysis done. Have them check the "silicon" level. That's the dirt that can get past your air filter.
I have the PG-7 on my '03 & the silicon levels on the last two changes were at 4 & 5. That's about what you'dd expect from a stock paper element filter. Each oil change was done at about 8000 miles.
You may want to put some grease around the filters seal, also, incase that's where dirt is leaking into your intake.
Good Luck.
Joe F.(Buffalo)
Good Luck.
Joe F.(Buffalo)
If you have ANY noticable dirt in the intake tube then your filter isn't working good enough, or there is a leak. That tube should be squeaky clean inside. I'll second getting the oil checked, and change it anyway. Can't hurt.
"I took the afe filter sock off today to clean it, and took the filter off to take a look at it and noticed a very small amount of dust in the intake tube, it has been 15,000 since I last looked at it, is this a problem is it normal?"
Something similar....If you almost finished eating a club sandwhich and noticed a small mouse turd spread on the bread, would that be a problem ?
Originally Posted by RYANGRAPHITE600
... I took the afe filter sock off today to clean it, and took the filter off to take a look at it and noticed a very small amount of dust in the intake tube, it has been 15,000 since I last looked at it, is this a problem is it normal? ...
L8r,...........dogger
As far as any damage goes your fine. My stock airbox was not locked properly and I did not catch it for 2-3K miles. That was 175K miles ago.
And my truck has more power today than when I bought it.
Just drive.
Just drive.
Originally Posted by Geico266
... And my truck has more power today than when I bought it. ...
Gieco is probably right if there was just a little dust on the intake tube. But what can it hurt to have an oil analysis. Heck you may be able to extend you oil changes and actually save money.
L8r,............dogger
2 oil or not?
How often does the pro-guard 7 filter need oiling, I have had mine in for about 10,000 and have done nothing to it. Should I oil it? Could that be were the dust is coming from?
L8r,.............dogger
I have found that if I ride my dirt bike with oiled sponge filters in very dust conditions there are types of silt, dirt, whatever that can bypass the most well oiled filter. And when I used to have a performance blown small block chevy in the fall here in Va. ( with K&N )there would be a small amount of dust on the air cleaner lid. I went back ot the pleated paper filter and saved the problems associated with all the oiled units. I also think ( imo ) that dirt can absorb the oil to some degree and therefore lessen the effectivness of the filter. But after all this Im still interested in trying the K&N filter on the crf450. I want to see how well it works. I am talking over 10 years ago when I had the oil type filters on my vehicles though things could have changed.
Geez, I drove home from the track with the air filter half off last night....no critters in the intake...no dust either. I figure that if it wasn't dusty....the bugs were getting pretty well incinerated at 1700 egts. ks
sinawalli
Mar 5, 2011 08:43 PM
surfram
Jul 17, 2006 02:06 PM
diesel_work
Oct 8, 2005 12:25 PM
z1bigtom
Dec 26, 2004 02:54 PM
sawboywv1
Jul 15, 2004 10:31 AM
