Adjustable upper ball jiont?
Old Mar 19, 2009 | 08:15 PM
tennessee's Avatar
Does anyone have them ? and does anyone make greasable front axle u jionts?
Old Mar 19, 2009 | 08:31 PM
jhenson's Avatar
An adjustable ball joint? Not sure I've ever seen one of these. I've been running Precision serviceable u-joints all around my truck and have had no problems with them. Got all of 'em from NAPA but don't know the #'s right off the top of my head.
Old Mar 19, 2009 | 08:38 PM
tennessee's Avatar
ya upper only shaped like a z take out grease fittin an adjust camber with 5/16 allen socket before u set taper suppose to help with alignment there american made carquest i think there moog? but not sure.
Old Mar 19, 2009 | 08:57 PM
1985cucv's Avatar
the precisions are 464's i just put 3 of them in my front axle shafts (there are only 2 axle shafts) i broke one cap due to being off kilter a little bit. but they are the 464's and greasable
Old Mar 20, 2009 | 07:06 AM
iifid's Avatar
I got my ball joints from car quest and they were adjustable pita to install and get the truck good enough to drive to the alignment shop.
Old Mar 22, 2009 | 11:54 PM
nickg's Avatar
I've done 3 trucks now, I used the moog ball joints from an 02(2nd gen ) they are like 70$ and easier to install, the "adjustable" BJ was 180$ so far no driving issues or complaints. I was put onto it by an parts guy who claimed back in the day there were no aftermarket choices for Ball Joint for the early 3rd gens, so they started using the 2002 ball joints.
Just finished doing my friends 04, he had x4 shot BJ, one trackbar bushing wore completely out and the tie rod at the pitman arm was trashed. drives like a dream now.
Old Mar 23, 2009 | 12:12 AM
Raspy's Avatar
I wanted and ordered offset joints before tearing into mine. But they had too much adjustment and I went with no offset after re-ordering a set off non adjustable ones.
You can also order them in various offsets to compensate, but you can't tell how much you need till it's all back together with new joints and on the alignment machine. Then it's too late. So I recorded the reading with all new joints and the next time (oh no, I hope not) I can ge the offset ones in advance.
I think the best approach is to max out the caster and live with a bit of unequal camber. Mine no longer pulls and drives at least as good as new.
DEFINATELY get the greaseable axle u-joints and the greaseable ball joints! And, of course, while you are in there, put on the free spin setup of your choice, the new '08 steering linkage and track bar bushings or replacement bar. In other words, do what Dodge should have done in the first place!
Old Mar 23, 2009 | 10:01 AM
dozer12216's Avatar
It is my understanding the offset joints may not be a durable as standard joints. So only use if you have a camber alignment wear issue that cannot be resolved by dropping toe to near zero. Only use as needed and if off by more than .5 degrees.
Old Mar 24, 2009 | 07:06 AM
Peterbilt's Avatar
MOOGs are adjustable and greasable.
Pete
Old Jul 10, 2009 | 05:59 PM
KevinG19yrsArmy's Avatar
I had a local place put on a set of uppers and lowers (adjustable) from CARQUEST at the same time I put on 4 michelins and had alignment done. When I drove away and got going down the road I'd turn the wheel a little to the left, about a second later the truck would respond, then turn it to the right, and a second later it would respond. It was kinda like stirring a soup spoon. So I took it back and told these folks, they said it would loosen up in about 500 miles. From there I left my old duty station en route to my new duty station with 5th Wheel Camper on the back. Most terrifying experience of my life, especially when an 18 wheeler would pass. Just ordered adjustable Moogs to have put on. Hoping my perception that Moog is better quality will fix my problem. Any thoughts?
Old Jul 11, 2009 | 09:29 AM
spitfire9137's Avatar
Dont get adjustables unless you absolutley need them to fix alignment problems.
Old Jul 11, 2009 | 11:37 AM
Ace's Avatar
Ace
Why not?
EdmontonCanada
37
Feb 4, 2016 12:02 PM
77machomopar
20
Dec 11, 2009 10:37 AM
wcbcruzer
22
Apr 30, 2008 06:58 PM
AZGEARPRO
Jul 17, 2006 06:42 PM
Jdonoghue
Jul 27, 2004 10:08 AM
