Adding a Leaf to Control Axle Wrap
Old Apr 21, 2008 | 10:22 AM
jrussell's Avatar
Originally Posted by GlennRMK
In the above pics are those two pieces of steel(don't have a bend to them like the leafs) under the rear leaf springs stock?
Mine has the same thing, but I thought they were not stock?
Yeah, those are stock. They're designed to only come in contact when there's a heavy load on the truck. It helps to support the weight when loaded and doesn't make the ride rougher when empty.
Old Apr 21, 2008 | 12:12 PM
TexasCTD's Avatar
Yep, mine are stock. The only thing changed/added on my rear axle is the MH rear diff cover, Rancho 9000 shocks, and the Lazarsmith traction bars.
Old Apr 24, 2008 | 02:40 AM
pupeperson's Avatar
JC Whitney sells some "traction control springs" which are essentially half leaves mounted on the forward half of the rear leaf springs. I tried a set and they didn't do the job, although they did help a little. The little Tuff Country traction bars did work however, also from Whitney.
97catintenn
May 28, 2010 08:29 PM
Jdoneff
May 11, 2008 07:02 PM
Joe T
16
Jun 12, 2007 12:11 AM
rharveysr
Jul 28, 2004 06:29 PM
