AC Compressor not engaging
Old May 9, 2018 | 10:29 PM
67HotRod's Avatar
Originally Posted by Intox
first thank you for replying. Now I must apologize for asking this question on 3rd gen truck forum. My truck is 2011 2500 Cummins. Are you familiar with 4th gen? Is ac the same design?
You should still have a thermistor, the newer trucks are easier to get to. They plug into a air box without disassembly, behind the glove box. IDK if it will fix your problem, but it does control the compressor.
Old May 10, 2018 | 03:06 PM
Intox's Avatar
I jumped power to compressor from the battery and charged with 134a.
Today I took it to local shop and he discovered a ground short, so far. He had to push my truck to the side and he agreed to trace the short later. I believe nhe will find tipm is the source of short.
Old May 15, 2018 | 09:23 PM
Intox's Avatar
Just to finish
the high pressure ground was not properly working. A in depth check revealed the tipm was the problem with the ground. Instead of replacing tipm I connected a additional ground to the ground wire coming from the high pressure switch. Also a 3 amp fuse was placed inline. The clutch engages and cold air at last
Old Jul 24, 2024 | 01:55 PM
DaveAlex's Avatar
My blend door(s) are broken but my AC was still working until yesterday when the idiot light is on, but no compressor engage. Do you know if the door actuator(s) positions have any effect on the ECM/TIPM wrt the clutch control? I did a quick pressure test and static pressure is OK in the system? Any help would be appreciated. Dave
Old Jul 24, 2024 | 01:57 PM
DaveAlex's Avatar
Did you jumper the clutch by removing the relay in the Fuse/Relay box or....
Old Jul 24, 2024 | 01:59 PM
DaveAlex's Avatar
I have replaced expansion valve,high pressure, clutch coil, and had the truck flashed. The ac clutch will engage with power from a power wire straight from battery to clutch coil. Is tipm a different component that is not reset when it is flashed?
I have seen this mentioned before...How do you reset the TIPM? 2006, Cummings.
Old Aug 16, 2024 | 11:38 AM
DaveAlex's Avatar
Thank you for the details.
Thks. I have located a manual with wiring diagrams and will follow your advice.
Where is the Low Pressure Switch on a 5.9D?
can i safely jumper it to test?
Does it Switch Ground or 12vdc?
Originally Posted by RanniWins
If the AC compressor clutch isn’t engaging and you have no power to the compressor, here arocated e a few things to check:
Fuses and Relays: Check the fuse and relay for the AC system. If either is bad, the compressor won’t get power.
AC Pressure Switch: The pressure switch could be faulty. If it’s not reading the system pressure correctly, it won’t allow the compressor to engage.
Wiring: Inspect the wiring to the compressor. Look for any breaks, loose connections, or corrosion.
AC Control Module: The AC control module might be malfunctioning. It’s rare, but it can happen.
Check these components first. If everything seems okay, the problem might be with the control module or the compressor clutch itself.
PCM
Apr 15, 2011 04:39 PM
zchornyak
24
Jul 7, 2007 08:35 PM
Kman9090
Jan 29, 2005 07:14 PM
Cumminstd1996
Feb 2, 2004 10:21 PM
