'06 A/C compressor not engaging
I turned-on the a/c in my '06 RAM quad cab today to find that the air coming out of the vents got no cooler at all. The a/c worked fine last weekend.
When I turn the fan on to any speed and press the a/c button, the button lights-up but I cannot hear the a/c compressor engage. No clicking or and different sounds at all.
I have seen LOTS of post about a/c on the forum. The truck only has 39k miles on it and the a/c worked fine last weekend so I'm hoping it is not the compressor.
Is there a fuse, relay or switch that would cause this symptom? If anyone has any thoughts, please pass along before I have to take it to the dealer? I appreciate the input. Phillip
low refridgerant will cause the compressor to not engage. keeps it from burning itself up. get a a/c servicing unit on it, vacuum it down, add dye and recharge.
I read this on another forum and found it of much interest as I did change my oil over the weekend: "had the same prob with no a/c. turned out to be a loose connection in the wiring harness plug at the compressor. my wires get pushed around every time i change my oil filter so they're susceptible to damage"
Anyone have any thoughts on that one. I cannot check the wiring until tomorrow. Thanks, Phillip
Oh, well. I got a chance tonight to check the wiring and it all is in tact and there does not seem to be a problem with it.
There are no fuses or relays under the hood for the a/c - at lease none labeled as such.
My next check will be to have the refrigerant checked. phillip
BigJim1965
21
Aug 16, 2024 11:38 AM
zchornyak
24
Jul 7, 2007 08:35 PM
Cumminstd1996
Feb 2, 2004 10:21 PM
