ABS light comes on turning left
Old Jan 27, 2012 | 03:40 PM
blkt6's Avatar
My ABS & Brake light turn on when turning left. The brake peddle also pulses. Any ideas on which sensor is bad? they are not hung up or pinched
Thanks
Old Jan 27, 2012 | 06:32 PM
greasy1's Avatar
Sounds like a broken sensor wire. A ohm meter should tell you which one.
Old Apr 11, 2012 | 10:31 PM
hot shot's Avatar
having the same problem with my 03.did u figure it out?
Old Apr 21, 2012 | 06:41 AM
TedT's Avatar
Also, check for play in the front wheel bearings.
Old Apr 21, 2012 | 06:42 AM
06RAM2500's Avatar
X2 on the wire.
hconstantino
May 3, 2010 12:15 PM
extremeshot
Jun 11, 2006 02:39 PM
jd4030
20
Oct 12, 2005 03:26 PM
pittom
May 2, 2005 08:25 PM
John H
Aug 12, 2003 09:16 PM
