70 vibration problem-reloaded
Old Sep 5, 2006 | 09:20 PM
PurNLoud's Avatar
sorry to just jump in here, but are any of yalls trucks doing this at 29-32mph as well? Reason I ask is my 03 did at both 29-32 and right near 67-71, dealer looked for two months and found nothing, I went off rd, bent the front shaft, took it off while waiting on replacement and no vibe at all, just my .02
Old Sep 7, 2006 | 12:33 AM
bgott's Avatar
Flamered, I have the 3.73's.
Old Sep 9, 2006 | 06:43 AM
flamered's Avatar
Well then I guess that makes sense then! Thanks for the reply bgott.
As for John Halter's suggestion - while I have not read the service manual yet for balancing the driveshaft, the thought of being under the truck while it is running at 70+ is a little unnerving. Maybe if only I had a proper garage facility...
PurNLoud - I do not have the vibration at lower speed, but pulling the front driveshaft is easy enough - I might try - or I might just wait and then complain again if/when I take my next trip down south!
Old Sep 9, 2006 | 07:17 AM
Geico266's Avatar
I had a vibration at 70 until I added ceramic beads to the tires. It's gone now.
Old Sep 9, 2006 | 07:53 AM
John Halter's Avatar
From: somewhere in northwestern ohio....Mansfield, Oh
I would hope the dealer would let you use his hoist since it should be his find not yours . I went for months looking and guessing and the only way to find it for sure is to take it up to speed and go under neath the beast . It is not that dangerous on a good lift but nothing I would do on jack stands and a creeper . It sure is a lot safer than standing beside a truck on a dyno under load . If I was to guess It would be the rear drive shaft out of balance causing it . The service manual has you take to large hose clamps and move them around the shaft until balanced . The manual explains better then me just ask dealer to print off section for you .
Lary Ellis (Top)
55
Nov 8, 2012 10:22 PM
dodgedsl03
Jan 18, 2007 10:08 PM
t-15 firefighter
Feb 19, 2005 12:52 PM
turbo6justin
Dec 4, 2004 11:05 AM
stuart01
Mar 27, 2004 08:25 PM
