Cooler line pressure on 48RE?
Old Sep 9, 2006 | 06:19 PM
handymantim's Avatar
Anyone know what the cooler line pressure is on a 48RE?
I just installed a brass coupling (for temp gauge) in the hot line going to the cooler and the line was not prefectly round resulting in a leak. I took the line back off and really cranked on the compression fittings which seemed to work. I'm curious what kind of pressure is in that line and I assume it varies with throttle position/load? Are we talkin' 10psi, 100psi, or 500psi? I'm asking because if it still leaks I'm going to either solder or braze the fitting onto the cooler line and I haven't decided which one to use.
Thanks!
upjeeper
Jul 30, 2021 07:08 PM
Tank_66
Jan 11, 2012 10:12 AM
rufushusky
13
Jun 14, 2010 09:27 PM
isb07
Nov 18, 2009 05:12 PM
RHC
Nov 22, 2007 08:52 AM
