5.9 engine interchange info HELP
Old Nov 6, 2010 | 10:13 AM
hemifred's Avatar
I wound up owning a 2005 pick up with a rod thru the block also the turbo and pump are missing. In an attempt to locate an entire motor I learned only 04-05 are listed as a drop in.
Checking further the factory shows the part number for a remaned long block assy, and it shows only fitting 04-05 yet if you pull the short block pn it fit’s 04-08 I guess it’s something in the head.
Can anyone give me more info what the differences would be with 06-08 and why they won't work should a complete engine be found. THANKS FOR ANY HELP
Old Nov 6, 2010 | 07:09 PM
Blake Clark's Avatar
Are you looking to drop in a 5.9 or a 6.7?
07 was the last year for the 5.9. If so, Ill move this over to the 5.9 section.
If it is a 6.7 then it would be a massive undertaking with different ECM tranny setup etc (auto anyway)
Im not sure if an 06-07 would be an easy job either with the canbus system controlling the ECM.
Old Nov 7, 2010 | 07:40 AM
hemifred's Avatar
please do I own a 6.7 so my favorites key took me here automatically
Old Nov 7, 2010 | 07:41 AM
hemifred's Avatar
what complete other years would be a drop in ? if any ?
Old Nov 7, 2010 | 07:45 AM
Hodge's Avatar
If you have an 05, then you have the 5.9.
crossy
Mar 20, 2013 10:45 PM
Firstgenfanatic
Mar 20, 2010 07:07 PM
furious70
Sep 2, 2003 10:39 AM
