Need some quick interchange help!
Old Mar 13, 2010 | 09:24 AM
Firstgenfanatic's Avatar
Question Need some quick interchange help!
I already posted in the conversion forum, but I figured more hardcore 1st gen guys might be able to answer this..............
Will a 1970's Dodge pickup interchange parts with a newer 89-93 CTD? I am talking doors, fenders, hoods, etc. I am looking at buying a 1979 Dodge crew cab and want to make sure it will work with my 93' CTD. If not, I just don't want to buy it and waste my time/money. I have heard rumors that the body lines are different on the 70's stuff. The mid 80's are a direct interchange? I really would like to get my facts straight before I go over later today to look at this 79' crew cab. Thanks folks!
Old Mar 13, 2010 | 09:57 AM
twichit's Avatar
yes the 80's are direct check this , this is my 93 with 88 w-150 tin everything got replaced doors,cab,fenders,hood aginst this this is wannadiesels truck idon't think there is any differance com'on guys bumpitybump
Old Mar 13, 2010 | 10:01 AM
bgilbert's Avatar
The body lines are different yes, but everything is bolt on. 72-93 is the interchange.
Old Mar 13, 2010 | 10:02 AM
what about the 70's stuff? specifically 1979?
Old Mar 13, 2010 | 10:03 AM
So how far off are the body lines between the 70's and 90's stuff? Will it look goofy if I use the 79' crew cab with my 93' front fenders & bed?
Old Mar 13, 2010 | 10:04 AM
bgilbert's Avatar
72-80 will have a different body line than 81-93. But it will all interchange. The ideal thing to do would be to update the bed, fenders and front doors. So your body lines match. From what I understand the rear doors on the crew cabs are the same from 72-85, the last year of the crew cab.
Old Mar 13, 2010 | 10:39 AM
Oh wow! I didn't know that! Yeah, I was only planning to use the crew cab itself and the rear doors. The doors, bed, fenders, and hood from my 93 CTD will be mated to this. Basically, I shouldn't have to worry about buying this 1979 crew cab and making it work with my 93' CTD. Thanks a bunch!!! I am off to check out this crew cab now!!!
Old Mar 13, 2010 | 11:44 AM
dodgenstein's Avatar
The late (91-93) clubcabs use the same bodylines as the 70's trucks. Note the rounded rooflines as opposed to the more angular lines of a regular cab. As long as you keep the fenders and doors together in respect to 70's vs 81-93 you won't have problems. There are some differences in the firewalls of these trucks and some fabrication is necessary if you are using a manual trans, but these trucks are very interchangeable back to 1972.
Old Mar 13, 2010 | 12:37 PM
In reference to door/fender match, I was referring to front doors only. If you study the character lines on the front doors, the lines end at the door lock, and follow the original 72-93 curve at the back of the door. The rear doors were the same on all crews from 72-85.
Old Mar 13, 2010 | 01:33 PM
NOTABLAZER's Avatar
One minor thing,you'll need to swap over the striker bolts from the newer truck.
Old Mar 15, 2010 | 07:56 PM
Ok guys,
I bought a 1980 Dodge crew cab 3/4ton 2wd. The whole truck is complete without the engine. Who on here has done a crew conversion by stretching the existing frame on their 1st gen CTD? I am looking at doing this and want to know more info, drawings, pictures, and measurements on how to do it. I would appreciate any help I can get. Thanks
Old Mar 15, 2010 | 09:52 PM
simplysmn's Avatar
Hey Firstgen you want a 4x4 crewcab frame ? PM me cause I am going longbed and don't need the frame so it's available .
Old Mar 15, 2010 | 10:02 PM
bigredbrick's Avatar
Be advised, the hole in the firewall for the HVAC is different on the '79 vs '93. I just found this out this weekend. So, I'll need to cut out that section of firewall from an '81-up truck and weld it in the '80 crew.
Old Mar 16, 2010 | 12:51 AM
Bigredbrick,
It sounds like you are trying to do the same exact conversion as me. I currently own a 1993 club cab 4x4 and just bought a 1980 Dodge crew cab 2wd longbed. I only wish more folks on here had pictures or a sticky of all the little details on doing a crew cab conversion. I just don't want the truck all ripped apart and then I'm stuck on some unforseen detail. Do you have pics of your rig?
Old Mar 16, 2010 | 03:14 PM
Trebor's Avatar
Here are a couple of firewall measurements for the drivers side:
When mounting the clutch master cylinder there is a 1/2" space between the face of the mounting bracket and firewall measured at the BOTTOM of the hole:
