48RE Trans Question
Old Oct 29, 2008 | 01:09 PM
tslewisz's Avatar
I think you're feeling the torque converter lockup, not a shift.
Old Oct 29, 2008 | 01:13 PM
wanna2500's Avatar
My 06 does the same thing. +1 for TC lock up. I don't think that year had the Tow/haul mode. If it does try that around town. I use it a lot when just puttin' around town.
Old Oct 29, 2008 | 02:47 PM
Hunter11's Avatar
Mine will do the same thing in tow/haul.
Old Oct 29, 2008 | 03:42 PM
Hamilton713's Avatar
It is in fact just the TC locking up. All is fine and it sounds normal.
Good luck and enjoy your truck.
Craig
Old Oct 30, 2008 | 02:16 AM
T & T's Avatar
Yes, the slip seems annoying. Once locked you really feel the power, but until then it feels sloppy. The torque converter slips until about 2000 RPM to allow the turbo to spool up fast, which is great for under 40mph, but sucks between 40 to 55mph until it locks.
You can override this with a "TC Lockup Switch" (do a search)...
Here's the original thread:
https://www.dieseltruckresource.com/...+manual+lockup
Old Oct 30, 2008 | 10:10 AM
cdennyb's Avatar
From: In Oroville, Ca., same house for past 46 yrs!
I also bet you coast when you lift off the throttle and you're around 40 mph huh?
That part I luv. It helps a bunch with mpg's. Put in a mystery switch and learn to use it... It'll come in real handy for the exact issues you have.
Old Oct 30, 2008 | 10:53 AM
alboy's Avatar
After adjusting the bands,mine shifted very crisp,not the sloppy feeling it had previously.It seems from different threads on here its generally the pressure solenoid or the bands not adj as the major problem.Mine does not hunt anymore,upshifts and downshifts immediately,very nice.
Old Oct 30, 2008 | 11:20 AM
T & T's Avatar
I don't think thie issue is how hard it shifts, it is getting it to shift and to lock - a computer programming issue.
It would be nice if you could program the speed at which it shifts and locks.
Old Oct 30, 2008 | 11:42 AM
T & T's Avatar
Because of the tire size, my trans doesn't lock until 55. Very annoying because most of my commute is between 45 and 55mph.
I have all the parts to build a lockup switch, but can't find the time to install.
The way I am setting it up is that it will have two switches, one that closes part of the circuit when just a sligh amount of throttle is touched, and the other is a steering-wheel button that will close the rest of the circuit and lock the TC.
The function is that the TC will only manually lock under throttle and when a momentary steering-wheel button (switch) is pressed (need to meet both conditions for it to work).
It is a safety so that it will unlock when you remove your foot off the petal. makes it more difficult to stall the motor. I may also use a locking relay that unlocks when the break is pressed (another safety feature).
In theory it should work well.
Old Oct 30, 2008 | 08:19 PM
al5608's Avatar
This is why i'm putting is a low stall converter. I can't stand when driving 35-45 mph, and the converter is not locked up, how high the stall is. It's just annoying. I talked to Goerend, and he said one of his low stall, single disk converters will do the trick. Lowers stall speed 600-800 rpm's. He said I can even add 70 more hp before needing to to a up graded valve body. While I have the trans out though, i'll put in a new high strength lever, apply strap and anchor. Only $85.00 more. So if someday I want more power. I just have to put in the valve body.
spopoff
Oct 23, 2011 07:20 PM
plessm
22
Nov 1, 2010 10:46 AM
rock crawler
Nov 19, 2008 06:56 PM
Rpainter
May 9, 2008 06:42 PM
wrm
13
Feb 14, 2007 05:38 PM
