48RE Towing Q
Maybe Not
I recently purchased a PacBrake for my '05. The PacBrake included a "secondary" Trans controller for my 48re and it covered '04.5 and '05 model years.
Prior to my PacBrake install, I noticed when exiting a limited access highway (55 mph or so) with the T/H mode off, I would release the throttle first to slow, then turn-on the T/H mode. The truck would then start downshifting right away. Although not as effective as the PacBrake, my T/H method did work. There was a TSB (21-006-07) issued in March of '07 to change the T/H mode operation. I elected not to do the flash as I liked the operation of the T/H as it is
I am guessing with the transmission controller that you have, it may work the same way as mine provided it wasn't flashed with the TSB.
Give it a try
Give it a try
Maybe Not
I am guessing with the transmission controller that you have, it may work the same way as mine. Give it a try
How do you like the Pacbrake on your 05. Does it have any issues with the trans controller? I also have a truck camper (about 4500-5000lbs loaded) and was thinking of getting the exhaust brake to help out some. I was running through the Smokies down in Tenn. earlier this year and had a little issue with heating up the rear brakes, no brake fade or anything too severe but makes me think what if the run was a few miles longer. Use to have a 10K lb. trailer that I towed and never had any issues cause it had its own brakes. How was the install?
Thanks,
Sticky
P.S. - sorry to the original poster for the hijack
belfert
25
Sep 14, 2004 05:50 PM
belfert
38
May 11, 2004 11:35 AM
