48re pump failure
Old Oct 15, 2008 | 10:29 AM
bamaboy's Avatar
48re pump failure
had DC replace front pump at 25000. truck sat at dealer for 3 weeks (parts were on backorder).... here we are at 35000 at its leaking at the inspection plate again and slipping with iratic shifting. My question is does low pressure damage clutches, TC, etc.. ? and what pressures are to low?
Old Oct 15, 2008 | 05:03 PM
dozer12216's Avatar
Slipping damages clutches. Would not damage TC in all probability. Clutches should be inspected due to slipage and perhaps KD band is badly worn from low pressure 1 - 2 upshift. The evidence will be in pan for damage.
Old Oct 16, 2008 | 06:35 AM
bamaboy's Avatar
dealer said they look at clutches ...but I pulled the pan after the first repair. and it had alot scum on the bottom and could not see the magnet
Old Oct 16, 2008 | 07:43 AM
j-fox's Avatar
I think it is time to check trans to engine alignment. The dowel pins are located wrong and it is wearing on the side-top/bottom/left/right, of the bushing.
Old Oct 16, 2008 | 08:13 AM
bamaboy's Avatar
can this cause pump failure? any really noticable damage to look at? I eventually want to put an aftermarket tranny in but I want to make sure I'm not replacing pump after pump
Old Oct 16, 2008 | 05:47 PM
j-fox's Avatar
When you get the converter out, take a look at the bushing in the pump. If the wear is only on one side, you have found the problem.
IPDiesel
Jul 29, 2015 09:57 PM
travelingman
Mar 26, 2011 08:08 PM
dodgetrucker75
Mar 17, 2011 09:15 PM
Old & Injecting
Aug 16, 2008 11:27 PM
The Domie
Feb 19, 2005 11:47 AM
