48re jumping out of 2nd
Old Feb 19, 2012 | 02:44 PM
Socal.pumper's Avatar
Hey guys iam new to this forum wondering if I could get some help from u guys I had the common problem of the 1/2 shutter shift so I did some resarch and did the gm govenor sileniod swap and also I did a band swap since I knew the band was on its last leg now when it shifts to 2nd gear it will pop out of gear and rev till I let the rpm drop and bearly give it throttle it will catch and feel fine any help would be great
Old Feb 19, 2012 | 04:36 PM
Oh btw 06 2500 160000 miles strightpiped s@b intakes no big power mods towing concrete pump since new never had any issue till about 150000 miles thats when the gps went out
Old Feb 19, 2012 | 09:32 PM
Ok come on anybody I know iam new to this forum but any ideas people????????
Old Feb 20, 2012 | 12:57 PM
no_6_oh_no's Avatar
2nd gear is toast. The band will not hold the power so it just revs. Let off and it shifts to drive and away you go. Got the same problem. Transmission is coming out, getting clutch packs rebuilt and a rigid band.
Enough of the flex band annoyance.
Old Feb 20, 2012 | 05:09 PM
I just did the band a few weeks ago ran great for about 3 weeks and then tgis started
Old Feb 20, 2012 | 05:38 PM
no_6_oh_no's Avatar
Did you replace the front servo and band strut at some point? What band did you put back in? Did you turn the drum down, replace it, or just use it as it was?
Old Feb 20, 2012 | 06:44 PM
Yes on the servo and strut the drum was not scored so I figured it was good iam no trans guy but I do turn the wrench daily fluid is clean just drove 300 miles towing the pump today and its still clean iam still using the stock tc if that matters
Old Feb 20, 2012 | 06:48 PM
Yes on the servo and strut the drum was not scored so I figured it was good iam no trans guy but I do turn the wrench daily fluid is clean just drove 300 miles towing the pump today and its still clean iam still using the stock tc if that matters oh and I swaped out the 1/2 accumolator to the billet stock one was fine but figured I throw the billet in just for piece of mind iam bout to find a shop and just dtop it off soon this isgetting old and I dont wanna get covered in trans fluid again just getting fed up
Old Feb 20, 2012 | 06:54 PM
But on the other hand I hate paying people I would rather smell like fluid and try.to figure it out myself I mean some of these people that work at these shops should no be allowed to make me a big mac let alone rebuild my trans and I dont have deep pockets to go with one of the 5000 trans
Old Feb 20, 2012 | 07:18 PM
Whoops sorry looks like my phone went crazy with the post
Old Feb 20, 2012 | 08:12 PM
no_6_oh_no's Avatar
Drum may not have been scored but may have too smooth, like a a brake rotor. You can't turn them much but the glaze would need broke up I think. Especially if the firts banded slipped and burnt itself up.
Did you use the stock flex band or go with a rigid? You have the classis xase of a bad band and you replaced all the bad parts. Maybe something else is leaking the pressure out on the band apply.
Does it go into a cutaway every it shifts to 2nd, just under hard throttle, or ????
I understand about some people only being fit to super size that order.
Old Feb 20, 2012 | 09:07 PM
Lmao!!! It only pops out when I I go over 10 or so lbs of boost with my concrete pump and hose in the bed without the pump its around 15 lbs of boost but once u get to lke 30mph I can ease into it and it holds and then shifts to 3rd I kinda was leaning towards a pressure issue I used a alto brand it looks better than the stock one I thought but like I said I am no trans guy
Old Feb 20, 2012 | 09:11 PM
no_6_oh_no's Avatar
Will it hold if you manually shift into 2nd and pour the power to it?
Mine is acting exactly like that but it is skipping 2nd. If it ever goes in it just revs. I know my band is toast. I can pull it down into 2nd and it will activate the band but will not hold much if any throttle.
I wonder if the band is not adjusted tight enough and it just isn't engaging?
Old Feb 20, 2012 | 10:14 PM
Texan1983's Avatar
mine just started doing the same. my tranny has 190,000 miles on it so i am pretty sure it's a different issue...
sorry to hijack, but what band is everyone using in the rebuild, and is turning the drum a common transmission shop procedure?
Old Feb 21, 2012 | 08:32 AM
no_6_oh_no's Avatar
If its glazed or grooved it will just tear up a new band. Can't turn them much so a lot of times its replacement.
Choice of band is different. Red or stock lining, depends on use.
