48 RE downshifting
48 RE downshifting
This weekend I had the opportunity to pull a twenty foot closed in trailer to Gulfport Mississippi to move what we could of a friends house back to FL. We had the trailer FULL of boxes and furniture. I'm guessing anywhere b/w 15-20K lbs plus what was in the bed of the truck, two 55 gal drums, one full of diesel and the other gasoline. The rest of the bed space was full of belongings and stuff. Was wondering if it's normal for the truck to shift out of overdrive (fairly hard) and race up to 3100RPMs when going up gentle inclinded hills. I'm not used to towing HEAVY loads like this. Is it better to take it off cruise control when going up and down hills like this or is it ok to let it do it's thing and stay on cruise control?
thanks Jamie
thanks Jamie
it is normal to downshift and speed up going up a hill. I assume you were going about 60 mph that is where it downshifts the hardest. And yes I just leave it in cruise controll going up and down the hills loaded. The only difference I notice with it in is if you are going downhill for a while and are gaining speed (above the set speed) it will downshift to try and slow you down. Other wise let er rip. and I am sorry to hear about your friends situation down south our hearts and prayers go out to all of those affected. Even us with $3.25 a gallon diesel because of it...
Some of those hills coming this way on I-10 are pretty long and steep with a good load. My Cummins powered Rams all bogged down to 58~mph and downshifted towing our 5th wheel up them. Mostly around Chattahootchee and Quincy I think it is. I tried to keep the rpm at 2900 or below. Shouldn't hurt a thing. Cummins runs the 5.9 at peak hp rpm full load for hundreds of hours at a time.
Our Hemi powered '05 does the same thing but one gear down. It'll downshift to second on the same hills our Cummins would call for 3rd and run 4200rpm. Not a problem for the motor but most folks cringe at the sound. I like the growl so it doesn't bother me. DC also ran the Hemi at full load high rpm for equal to 150k miles using dino oil.
No harm done with either...
Shame you didn't stop at the Flying J at I-10 and Hwy90. They have a scale and the restaurant has the best fried chicken and cooked greens you've ever tasted! On your way back you should stop, weigh in and have some!
I don't think the Cummins engine produces peak performance nor good fuel economy when towing up hills at rpm's over about 2,400 to 2,500. Also, I personally don't like to run my engine at what I consider to be excessively high rpm's. Consequently, I don 't use cruise control while towing in hilly country because of the 48re downshifting too early. I actually ease off the excellerator just a little when towing a hill that I know will require a lower gear. When the truck pulls down to approximately 1,800 rpm I push down on the excellerator just hard enough to get it to shift to third gear and then I try to hold the rpm around 2,400. When nearing the top of the hill and the truck starts to easily speed up, I let the rpm's go up to about 2,600 rpm and then I let off the excellerator to let the transmission shift to 4th gear.
Cummins
I second the cummins motor being able to run hard. While in College out at Pitt Bradford, up at Johnston New York is where they produce the Cummins that goes in commecial trucks and boats. As soon as there assembled there put on a dyno at 100% load the minute it fires up. They circulate colant through the motor to warm it up, fire it up and run it wide open for 24 hours at that load. It's amazing what they do to break them in. So just think of how we take care of them, the fact that most of our motors where run at 100% load for 24 hours before they made it into our trucks...... Turst me, I doubt many people ever push there motor to beyond the safe limit. It's amazing what these motors will do. We have one mounted to a water pump at work, when it runs, it runs hard, and non stop. WE also have the Cat generators, god help me if I could put that in my truck 2400 hp and 10,000lbs of torque,
when you use cruise control while pulling a load it does not sense the hill until you are already starting up it
so to catch up the speed you have lost it drive deep into the throttle thus causing the downshift
if you do not use cruise control and gentle push the throttle before you start up the hill you will not downshift near as much
hope this makes sense
your 315s dont help matters either
Mijpa, I don't remember the the exact speeds because it has been a few months since we took a trip with our 5th wheel camper. We will be taking a trip to Yellowstone in a week or so and I will make specific note of the speeds and rpm's then. The best I can remember, I usually climb moderate to steep hills at about 55 to 60 mph in 3rd gear and I time the shifts so that my rpm's usually don't go over about 2,400 to 2,500 rpm's.
Jc9995
Jul 11, 2004 05:45 AM
