47re valve body in a 48re trans
Old 09-23-2009, 11:36 PM
S/P G671's Avatar
does anyone know if this will work or not,im having nasty 1-2 shuttle problems on med. throttle and i have a 47 re valve body layin around and wanted to swap it out just to see if it fixed my problem.
Old 09-24-2009, 10:22 AM
cdennyb's Avatar
Location: In Oroville, Ca., same house for past 46 yrs!
yea, it should be fine for the test.
hey, do you have any front wheels and tires for a dragster? like the 2-1/2" wide x 17 ones?
We have a T/D too and it's getting some new panels and paint along with a few other goodies and those are on my list.
Old 09-26-2009, 12:37 AM
bob4x4's Avatar
03 04 maybe the 05 has no tv cable
Old 09-26-2009, 08:46 AM
Spooler's Avatar
05' has the electronic TV cable and it will not work correctly with the 47re VB. If you want to address the shuttle shift get a DTT shift enhancer or similar product.
Old 09-26-2009, 09:15 AM
no_6_oh_no's Avatar
Actually, the activation of the TV valve is done the same way, the center post on the shift tower of the VB. The TV activation is normally not an issue.
If the VB is setup correctly it should work fine. There are some minor differences in how the VB does its job that might cause problems but its not a given. Some of the builders actually like the earlier VB's as they say they are easier to get to function correctly.
Old 09-30-2009, 11:33 PM
S/P G671's Avatar
i did fix the problem by removing the sonax tv valve and putting the stock one back in< i have instaled hundreds of the sonax valves and never had this problem.but hry,theres a first for everything.
kevellis32
27
06-23-2022 01:42 PM
Bersaglieri
22
11-05-2007 11:30 PM
joeybaker82
04-15-2007 06:49 PM
downlow
02-13-2007 07:45 AM
storx
28
01-28-2006 08:12 PM
Quick Reply: 47re valve body in a 48re trans
