4 wheel drive problem
Old Aug 30, 2010 | 11:44 AM
Phil705's Avatar
This is a 2005 Dodge Ram 3500, 5.9 Cummins diesel, automatic, 4WD with about 50,000 miles.
The problem is that when I shift into 4WD High, it won't stay in gear at any speed. The shift lever just kicks back into 2WD, unless I phyically hold it into the 4WD position. Also, sometimes when I put it into reverse it doesn't catch, until I wiggle the shifter.
Any thoughts as to the cause??
Phil705
Winthrop WA
Old Aug 30, 2010 | 06:37 PM
steelblitzkrieg's Avatar
DTR Detective
Move the shift linkage about a 1/4" and retighten. Make sure to mark the present location of it with a sharpie. I had the same issue last winter. It would stay in 4hi for anywhere from 10ft to 2 blocks then kick out.
L.J.B.
Jun 27, 2014 10:21 AM
roxxx
Apr 13, 2009 05:15 PM
04ctd
Dec 7, 2007 08:19 PM
gman2310
Sep 27, 2006 12:08 AM
Teddy
Nov 2, 2002 01:56 AM
