4 wheel drive problem
Old Mar 30, 2009 | 10:10 AM
jmmcdona's Avatar
This past weekend I tried to put the truck in 4 wheel drive and all I got was a bunch of grinding, the front end tried to lock up but it would slip out and not engage. I have an auto tranny that has been replaced, with the manual shifter in the floor for the 4 wheel drive. Anyone know what could be going on? I tried 4hi and 4low forward and reverse same problem.
Old Mar 30, 2009 | 10:48 AM
wwm's Avatar
wwm
were you trying to do it on the fly?
Old Mar 30, 2009 | 11:52 AM
bradler's Avatar
grinding from transfer case or front end, like diff? maybe loose chain slipping in x-fer case...
Old Mar 30, 2009 | 12:32 PM
jmmcdona's Avatar
Just wondering but don't these trucks engage the 4X4 using a vacuum of some sort that could have got pinched or a hole in it when my guy was installing the transmission.
Thanks guys,
Jason
Old Mar 30, 2009 | 01:44 PM
05 CTD2500's Avatar
these trucks don't use a vacuum like the 2nd gens, it is engaged and disengaged in the transfer case manually since you have the floor shifter, the front driveshaft is spinning any time your moving thats why lockout hubs are good for mileage gains on these trucks.
is this the first time you've tried to use it since having the new transmission installed? if so I'd take it back and have them fix it.
Old Mar 30, 2009 | 02:29 PM
sdmark's Avatar
If you were not moving and had the truck in gear when engaging 4wd, I would expect that. If you were rolling and the truck was in gear and this happened, I would not expect that. Also, having the truck in motion and or having the trans in N makes it easier for the Tcase to find the gears.
Hope this helps out.
Old Mar 30, 2009 | 09:02 PM
Asher's Avatar
I bet you need to get the linkage adjusted... Man I love my ****...
Old Mar 31, 2009 | 07:19 AM
jmmcdona's Avatar
Thanks guys
I would like to thank ya'll for your input, I'll talk to my trans guy today.
Jason
L.J.B.
Jun 27, 2014 10:21 AM
roxxx
Apr 13, 2009 05:15 PM
04ctd
Dec 7, 2007 08:19 PM
gman2310
Sep 27, 2006 12:08 AM
Teddy
Nov 2, 2002 01:56 AM
