4 wheel drive
Wetspirit, it doesn't matter if the torque is going to the ground or not. That is only serving to confuse you as to where the power goes. You are correct in that in a straight line with no wheel slip between the tire and ground both tires are receiving equal power. I used the example of a tire in the air because it shows where the force goes when you give the axle more power. From a stand still both tire are motionless. You give the axle power through the transmission and what happens to the tire in the air? It begins to accelerate and spin. That is where the power is going on the open differential.
I wish I could think of a better way to explain this wonderful machine, but the best thing is to go play with one. You can jack up your truck and try a few experiments or find one at the junk yard with the cover off to play with. You'll see what I mean.
Wetspirit
How would you explain torque steer in a FWD car then? If what you are saying is true, both the motionless tire and the moving tire receive 1/2 of the input torque. It is correct to state the differental split torque but not always equally. I would be more inclined to belive you if you signed your name with BSME, MSME...etc
jkitterman,
Torque steer on FWD cars is a combination of many things. Unequal length half shafts, tire offset, scrub radius, tires and road conditions.
With unequal length half shafts, you will also have unequal weight of shafts. The higher weighted shaft will require more of the equally divided torque itself to get moving or accelerate than the lighter one, leaving less for the tire.
With scrub radius, the distance between the center of the contact patch of the tire and the steering axis, is ideal equal on both sides, but often not perfect. When torque is applied the tire is trying to pull itself around the steering axis, causing the car to try and steer itself. If the scrub radius is not equal on both sides than you get torque steer. Also, if you have a different offset than factory, your srub radius could be even worse.
Road conditions also cause a problem. If you are driving on a perfectly smooth road (yeah right) then traction would be equal on both tires, but that is rarely the case.
Hope this helps.
Gord.
BSME
Hope this helps.
Gord.
BSME
L.J.B.
Jun 27, 2014 10:21 AM
roxxx
Apr 13, 2009 05:15 PM
04ctd
Dec 7, 2007 08:19 PM
gman2310
Sep 27, 2006 12:08 AM
