4:10 gear set
Old May 9, 2007 | 01:45 PM
Ramcam's Avatar
4:10 gear set
Have had my truck in the shop for a week now with a drone between 95 k and 105 k they have put in new engine mounts trnny mounts a new resonator and tailpipe none of this worked .The sevice manager said putting in 4:10 gear set should get rid of this drone as it will change the rpm when the torgue convertor locks.How much mileage would i lose with 4:10s?
They said that this drone is a characteristic of long box quadcabs can you believe it.If i had known it was a(characteristic) i never would have bought this thing in a million years.So now the district service guy is going to be talking to them about this and i have to get this resolved .I don't want it as is.Pro's and cons of 410s should i go that route?
Old May 9, 2007 | 08:36 PM
gus's 03's Avatar
4.10', 35's and a 6 speed gets me 24+mpg....
Old May 9, 2007 | 08:56 PM
walkram42's Avatar
Can't speak for 4.10s but the cruising speed with my 4.56 is not good. Running about 2250rpms at 73 or 74ish. It is not a great comparison but something to consider with changing the gearing.
Old May 9, 2007 | 09:15 PM
C Schomer's Avatar
I love my 4.10s but I never go very far without the 5er and that's when I want them the most. I get 18-19 empty and 12 towing. If you don't need 4.10s, I think I'd try an aftermarket muffler and resonator. Craig
Old May 9, 2007 | 10:21 PM
Spooler's Avatar
What kind of exhaust do you have? When I put my exhaust on I had the tip in to close that caused a drone issue. I moved the tip out a good ways and bingo, no more drone. If you have the factory exhaust put a tip on it and extend it out past the side of the truck by an inch. It will correct your drone issue. Hope this helps.
Old May 10, 2007 | 02:43 AM
Ramcam's Avatar
well i am a bit surprised they never extended the exhaust tip i am putting a list together of a couple more things they should try.They have hung weights on the exhaust and nothing makes a differance.Changed the pinion angle took the front driveshaft off all new driveshafts in the rear and still an awfull drone.i wonder if anything in the tranny could cause this?The scary part is they are now calling this a <characteristic >they are trying to imply it is normal operation if it is i wonder why they have tried to fix it in the first place.They also said that all these trucks have this drone but i don't hear that on this site very often.oh and i have the stock exhaust
Old May 10, 2007 | 08:38 AM
rockcrawler304's Avatar
My first thought while reading your original post was the same thing. If this is a "characteristic" then they would have said it from the start. Not throw a bunch of parts and time at it and then say it is normal. They are lost, and now just want you to leave!!
Old May 10, 2007 | 07:30 PM
RCinMesa's Avatar
You got a dealer to do all that work and replace all those parts at their expense? That's amazing after having read some of the non-service horror stories on this site.
Old May 11, 2007 | 02:36 AM
Ramcam's Avatar
yes they have put in all those parts and there going to put in the 410's on tuesday.they have also given us a rental car during all of this.So i will say they have been very helpful.I just hope that **** drone goes away.
Old May 11, 2007 | 01:05 PM
tonyiii1's Avatar
May sound too simple, but I have seen tires do this. Throw a new set on and see if it changes, if it does... there you go!! If it doesn't don't buy them.
Old May 13, 2007 | 11:36 AM
dieselnewbie's Avatar
On average you'll lose 1 mpg with the 4:10's vs. 3:73's.
IMO, I don't know why anyone would have anything but the 4:10's in a truck with the kind of pulling power the CTD has.
Make's the truck more capable.
All the Dodge dealers in my area have nothing but 4:10's in the CTD trucks on their lots.
If you want 3:73's you have to special order them.
DT.
Old May 13, 2007 | 09:04 PM
Duallydog's Avatar
I've had different year model trucks with 3.55, 3.73, and 4.10s, the best cruising mileage was from the 97 with 3.5(3, 4,or 5)(can't remember exactly), the next best peak cruising mileage is my 04 with 3.73, then it's a toss up between the 91 with 4.10s and the 2000 with 3.55. Cruising consistency was the 91 with 4.10s (got the same mileage on the hwy or running back and forth into and around town) Pulling mileage is hard to compare, but the 91 with got the best then the 97, 00, and 04 are similar pulling the same trailer. The main trailer I pull I didn't have when we had the 91 and the 97, and I really haven't used the 00 enough to measure the fuel consumption, but I can tell you my 3.73s pull better in the higher gears.
Sorry for the long story and no direct answer. But if you want my theory, running empty as long as you stay at the same rpm instead of the same speed, the 4.10s would get the better mileage since the engine is working less to make the same load move.
paulk124
15
May 19, 2009 07:09 PM
Mike M
Nov 19, 2007 05:17 PM
ronc
Oct 18, 2007 04:12 PM
got...DIESEL?
Jan 27, 2005 09:13 AM
Dlcorrie
Sep 12, 2004 12:06 AM
