3rd gen's bad injector pump's
Old Feb 8, 2006 | 06:04 AM
armyret01's Avatar
armyret01
My pump went out at 92K. It was leaking and I thought it was a gasket so I called the dealer and they said, " get it here quick". It was replaced under warranty
Old Feb 9, 2006 | 07:14 PM
LCH's Avatar
LCH
Originally Posted by underwoodtransp
I asked my tech today if he checked my lift pump. He told me there is no reason to. If the lift pump were bad my truck wouldn't run at all. He said the newer trucks' injector pumps don't have enough pull to get fuel to the pump without the lift pump running. He also stated that since the 04's came out he has only done 2 injector pumps and mine was the second. He told me not to worry about it.
Asked my tech to check my lift pump when he replaced my cp3. He found that the lift pump flow was under speck and replaced both, said the lift pump was starving the cp3. Your lift pump can be dieing a slow death and taking your cp3 with it and you will never know unless you put a gauge on it. I didn't notice any performance loss either. I'd want it checked, my 2 cents..LCH
Old Feb 10, 2006 | 08:18 AM
farmer dave's Avatar
Just curious about this topic. Is there a way to put a fuel pressure gauge on like the 2nd gens? Also, is this problem as big as the lp in the 24v 2nd gen?
Old Feb 10, 2006 | 09:35 AM
underwoodtransp's Avatar
Yes you can put a pressure gauge on your filter cover. Just make sure you isolate it before you bring it ito the cab. I know geno's has a cap that is threaded already but I have seen many guys drill and tap their stock cap.
Old Feb 10, 2006 | 10:11 AM
So the fuel is pressurized after the filter? Not real familiar with the 3rd gen yet, but I want to be familiar when I get my next truck.
Old Feb 11, 2006 | 10:42 AM
yes it is highly pressurized after the filter. If it was before the filter the filter media would have no chance of surviving. We are talking 20-25k pressures here. The "lift pump" in the tank only provides fuel to the injector pump in bulk not pressure. It reduces the stress on the injector pump since most pumps are better pushers than pullers. The filter is between the lift pump and the injector pump.
anonymous_1
13
Apr 30, 2020 04:29 PM
BRUISER
Feb 2, 2015 11:25 AM
1qckdodge
Mar 5, 2007 09:53 AM
barracuda
25
Mar 16, 2006 11:41 PM
