35's and rubb age
Old Apr 1, 2007 | 09:28 PM
vj_M's Avatar
35's and rubb age
I just hammered on some 35" procomps mt on the stock chome rims, they rub when i cut er hard even on flat ground. If i hammer 1/2" or 1/4" wheel spacers on there would that work or are theyhard on wheel bearings.?
or will a leveling kit fix this.?
Old Apr 1, 2007 | 09:32 PM
35" 05''s Avatar
levelin kit. dont know if spacers would help
Old Apr 1, 2007 | 09:34 PM
vj_M's Avatar
A levelin kit will fix this.?
Old Apr 1, 2007 | 10:10 PM
bob4x4's Avatar
No,they are most likely rubbing on the control arms.Correct?
Bob
Old Apr 1, 2007 | 10:52 PM
vj_M's Avatar
yes they are the upper one i do believe..
Old Apr 1, 2007 | 11:17 PM
TexMexCowboy's Avatar
Well first of all when i had 35's with my leveling kit and stock rims they still rubbed on the arms it was only when i put different rims that it quit rubbing. I have 37's now and still have the leveling kit but i have all four fenders cut 2". and they only rub on the bumper a little. i am going to get rid of the bumper and put a pipe bumper on it.
Old Apr 2, 2007 | 10:17 AM
Pooter's Avatar
The only way they wont rub is offseting the wheel out further, aftermarket wheels.
Only problem there is, the further you go out, the more its going to rub on the back of the wheel opening on the fender, and back side of the front bumper.
Im fine witha little rub at full lock on the upper control arm, I rarely go full lock and when I do its at slow speeds and hasnt really messed up the paint on the control arms or really any rub pattern on the tire.
Old Apr 2, 2007 | 01:03 PM
ptgarcia's Avatar
A 1/2" spacer will most likely cure the rubbing but I don't know if I'd recommend it. The best fix is new wheels with a little less backspacing. With 17"x9" wheels 5.75"-6" backspacing is perfect. Good luck!
Old Apr 2, 2007 | 01:53 PM
JMalone's Avatar
My 315/70/17s/stock wheels rubbed the control arm at full lock. I installed a set of 2" leveling spacers and that eliminated the problem.
I hope that helps!!!
Old Apr 2, 2007 | 07:22 PM
chris.willis.68's Avatar
Rubbing
I have 35 12.5 R17 Toyo Open country MTs and after installing 2 inch lift spacers they still rub slightly at full right turn, But considerably less than the previous state... Finally I can get a coffee in a drive through without driving over curbs.
Old Apr 5, 2007 | 03:38 PM
sdmark's Avatar
I had this problem when I first got a lift and 35s. I originally had Pro Comp Steel 17x9s. The offset meant rubbing on the fender. I now have some MTs with more than stock offset but less then the Pro Comps. I want to say +4. No rubbing anywhere, anytime.
Old Apr 5, 2007 | 03:44 PM
Black SunShine 04's Avatar
My tires don't rub at all but I have to keep the snow cleared out of there or it'll rip my mudflaps off.
Carpenter74
16
Jul 27, 2013 04:51 PM
Mar 20, 2003 12:41 PM
NWDave
Feb 25, 2003 07:25 PM
NWDave
Nov 18, 2002 07:09 PM
