3.42 swap in a 48re truck?
Old Apr 26, 2012 | 05:27 PM
07_Ram's Avatar
debating on swapping my 3.73's out for a set of 3.42's but I'm worried on how the low gear ratio and only 4 speed trans combo will do when it comes to mpg's. I tow no more than an atv or small fishing boat so I dont need any more power, just improved mpg's.
Thoughts?
Old Apr 26, 2012 | 07:14 PM
NJMurvin's Avatar
Thoughts?
Bigger tires/wheels would be simpler/cheaper. Seems like it would take a lot of miles to break even on the expense of changing gears. 4WD or 2WD?
Old Apr 26, 2012 | 07:42 PM
Spooler's Avatar
If you get a Hamilton 178/208 with those gears you will get even better mpg and gain some performance. It pulls really good down low in the RPM range.
Old Apr 26, 2012 | 09:20 PM
07_Ram's Avatar
How would bigger tires improve mpg?
Old Apr 27, 2012 | 05:22 PM
NJMurvin's Avatar
I should have said "taller" tires. It simply changes your overall drive ratio. This has been discussed in some of your other threads on this subject. Have you actually priced out changing the gears?
Old Apr 28, 2012 | 01:12 PM
DBLR's Avatar
FYI its Tall & Skinny tires that help improve mpg numbers.
5.9Excursion
Cummins Conversions
442
Dec 22, 2014 12:10 PM
DodgemnLeavem
Jan 20, 2010 10:25 PM
bigman
Jun 9, 2008 10:44 AM
RDR
Mar 13, 2008 02:35 AM
schwzi
Sep 23, 2007 08:36 AM
